My S2 Rebuild and Restoration... New Engine Build
Old Oct 17, 2005 | 01:30 PM
JamesS2RS's Avatar
JamesS2RS
Default My S2 Rebuild and Restoration... New Engine Build
Since I was a wee boy I have wanted an Rs Turbo for some strange reason… Four months ago I decided it was time to own one so I looked all over the internet joined this site and when out and brought one. The car I brought cost me a lot of money as it was a completely original S2 1988 with 40k on the clock I was thinking to my self as I joined the A14 on the way back form J28 what a good car I had brought when I herd the lovely sound of an alternator belt flying off under my bonnet (o joy!!!) So I continued down the A14 until my battery when completely flat then called for a low loader to pick me up and take me home…
This is where it all started!!!!
I was on my way home in the low loader and I called my best mate / grease monkey (Minty off Eastender)(Lewis) to get his arse down Halfords and get me a new belt we put it on and started her back up. I drove the RS round for a about 170 miles before my brain had a seizure and I decided to strip it down to a bear shell and rebuild it (Nuts!!!)
I will try and put some picture on this afternoon if I get time
Old Oct 17, 2005 | 02:45 PM
JamesS2RS's Avatar
JamesS2RS
Demolition has started!
Arr look what i found!
Old Oct 17, 2005 | 02:49 PM
adamS2RST's Avatar
adamS2RST
Looks like a lovely example, very much how I got mine (had done 50K tho ) Have you stripped any more yet or is that it? hopefully you wont find too much of the car cancer Anyway, what are your reasons for stripping this minty looking original S2?
Old Oct 17, 2005 | 03:00 PM
Oh some piccys ,keep up the good work ,does look a minter to start with
Old Oct 17, 2005 | 03:16 PM
JamesS2RS's Avatar
JamesS2RS
Adam,
The reason I am doing this to my lovely looking Rs turbo is because under that mint body work she not that lovely … This is gonna be a full restoration I have nearly completed the underside of the car and I will post them Pic’s when I get in from work.
This is what it did look like on the underside...
Naughty bit of rust....
Wait until i put my pic's on tonight she is looking sexual Chocolate underneath
Old Oct 17, 2005 | 03:35 PM
JamesS2RS's Avatar
JamesS2RS
The engine is half out and will be having a full rebuild with a few adjustments to make it a bit more fun...
The engine spec is gonna be:
Piper cams
K&N Panel filter
Magnex Exhaust
Chip
-31 act
New I/C
New Rad
New Started motor
New Alternator
New Hoses
Might go for a stage one or two turbo as well
Old Oct 17, 2005 | 04:12 PM
adamS2RST's Avatar
adamS2RST
Cool mate, That underside don't look too bad at all, only mostly surface corrosion on the suspension parts etc What's the other bit tho, it looks like a weird angle of the rear arch? If so, i've seen a hell of a lot worse mate! You'll have to have a look at my S2 underside tidyup thread when you get a chance
Look forward to seeing the "sexual chocolate" pics later
Old Oct 17, 2005 | 06:05 PM
Davey8oy's Avatar
Davey8oy
white ones are the best imo!!!!!!
keep the pics comin
Old Oct 17, 2005 | 07:47 PM
JamesS2RS's Avatar
JamesS2RS
A Few pic's for thhe underside: -
Ployflex bushes, Spax suspensions, 25mm pi lowering springs, Zoo Motorsport rear disk conversion.
What do u think guys
Old Oct 17, 2005 | 08:21 PM
adamS2RST's Avatar
adamS2RST
Very nice mate, much better, so you got the zoo kit then
Old Oct 17, 2005 | 08:32 PM
JamesS2RS's Avatar
JamesS2RS
Yep nice little kit and easy to put together.... How does it perform?
Old Oct 17, 2005 | 08:41 PM
adamS2RST's Avatar
adamS2RST
Erm, well I've not had any problems yet, I've got ST170's up front and ABS removed, and it stops very well and straight even in "taking the piss" braking situations Won't do much tho the rears, unless you have a bias on them I guess and adjust them but then it'll lock up and spin out! How'd you get on fitting them with the bolt clearance etc?
Old Oct 17, 2005 | 08:58 PM
JamesS2RS's Avatar
JamesS2RS
The blots hit the back of hub so I called zoo up and he told me to shave a bit of the bolts with an angel grinder and they seem fine. then I just put a bit of lock tight on the bots and put them in... U? U gave me the name x factor for the front st170 brakes but I could nt find him on ere do u have his number or anything??
Old Oct 17, 2005 | 09:22 PM
adamS2RST's Avatar
adamS2RST
Yea, same problem, and same resoloution
Jay @ Xfactor...
https://passionford.com/forum/profil...ewprofile&u=82
http://www.xfactormotorsport.co.uk/
Old Oct 17, 2005 | 09:26 PM
Moondust_crust's Avatar
Moondust_crust
fook me mate looked like the car had been living by the sea, looks alot better now though, did you remove all the old ford underseal? regards mark.
Old Oct 17, 2005 | 09:46 PM
adamS2RST's Avatar
adamS2RST
Didn't look bad at all I've seen car's by the sea, they not like that!
Old Oct 18, 2005 | 07:09 AM
Looks stunning mate
Old Oct 18, 2005 | 08:27 AM
JamesS2RS's Avatar
JamesS2RS
I removed all the old underseal and rust then coated it with 4 coats of primer, 4 coast of white and I am going for 4 coats of stone guard as well.
Adam thanks for your constructive comments and your help with the links…
I am a bit worried about the rear disk conversion them bolts are gonna play on mind…
Old Oct 18, 2005 | 12:43 PM
JamesS2RS's Avatar
JamesS2RS
For some crazy reason I am taking the car back a part tonight and any part that can be powered coated is going off to central blast cleaning in the morning (fooking Mad)
Just spoke to a very nice chap there who said he would do the lot for 250quid.
Old Oct 18, 2005 | 01:49 PM
adamS2RST's Avatar
adamS2RST
That sounds good What bits are you having done?
Old Oct 18, 2005 | 02:17 PM
JamesS2RS's Avatar
JamesS2RS
Wish arms, roll bar that sort of thing I think I am gonna loss the red bits and just have it black and white under there... what do u reckon??
Are you going to take yours round the show's next year?
Old Oct 18, 2005 | 03:07 PM
adamS2RST's Avatar
adamS2RST
Ahh, yes I see, will look cool, kept mine black, although didn't get the stuff powder coated Was kinda held back on a fair few things and needed the car done in the end It'll look cool mate
I did the shows this year, I don't show my car though, it's not good enough for the bufty stuff But usually get on the Passionford stand at the shows
Old Oct 18, 2005 | 03:34 PM
JamesS2RS's Avatar
JamesS2RS
I was think maybe a few of us who have done all our own rebuilds should setup a few stands next year? what u reckon
Old Oct 18, 2005 | 04:32 PM
Good stuff ,central blast do a very good job
Old Oct 19, 2005 | 08:45 AM
JamesS2RS's Avatar
JamesS2RS
My friend Dave (engine builder) come round yesterday and all I was left with was a gearbox.... My new engine is getting built
Ill take some pic's later...
Old Oct 20, 2005 | 10:26 AM
JamesS2RS's Avatar
JamesS2RS
Default Update
Quick Update:
All this week I have been taking apart the engine bay which I finally got done last night.
My friend Minty has been removing all the chassis components and getting them ready to send to central blast cleaning which are gonna look sexual!!!
I’ve booked the shell in for it re-spray on 31 Oct so in the next few weeks there gonna be some really interesting photo posted.
I will post some pics of central blast work when it returns.
Thanks,
Jim.
Old Oct 20, 2005 | 01:35 PM
adamS2RST's Avatar
adamS2RST
Look forward to that
Old Oct 20, 2005 | 02:53 PM
maxest's Avatar
maxest
Who's painting the car for you?? Were you not tempted to do all this to an S1?!?!
Old Oct 20, 2005 | 03:21 PM
JamesS2RS's Avatar
JamesS2RS
The car is getting painted by a company called piant works in harlow essex ive seen his work and it is second to none...
Arr S1 That is my next one on the list.... But i am gonna build an animal with serious power.... I wanna look into running a focus rs lump in one or something... looking for around 350bhp mark.
Something that will give my M3 a run for it's money....
Old Oct 20, 2005 | 04:10 PM
nice work look forward to the updates
Old Oct 25, 2005 | 09:37 AM
JamesS2RS's Avatar
JamesS2RS
Default udate
Just a quick update:
Been busy all weekend stone guarding the underside again and the finish this time is mega I am off to central blasting on friday to pick up al my bit's and bobs And rebuild the car before monday as it is getting picked up to get sprayed I carnt wait to get it back from the sprayers then you will see some real progress on ere...
Thanks
James
Old Oct 25, 2005 | 11:15 PM
ford crazy's Avatar
ford crazy
looking very nice mate
Old Nov 22, 2005 | 08:57 AM
JamesS2RS's Avatar
JamesS2RS
*****Up Date******
I decided to strip the car down again and give it a few more layer of protection and it is look so nice when I look back at the pics when I brought the car I cannot believe how much I have done and how fair the car has come along…
I when up to central blasting in Banbury with all my wish arms and roll bar and the work they have done is outstanding I recommend them to anyone + there pricing is spot on.
Any positive input would be nice
Old Nov 22, 2005 | 09:08 AM
Milkybar Kid's Avatar
Milkybar Kid
very nice , keep it up .
Old Nov 22, 2005 | 09:09 AM
Brian's Avatar
Brian
Looking good mate
Brian
Old Nov 22, 2005 | 09:19 AM
maxest's Avatar
maxest
Does look v.nice! Were you not tempted to use new bolts....
Old Nov 22, 2005 | 09:31 AM
JamesS2RS's Avatar
JamesS2RS
Can you still buy all the bolts from ford?? If so then i will replace them
Old Nov 22, 2005 | 09:36 AM
adamS2RST's Avatar
adamS2RST
Excellent work mate Car's looking really good
Old Nov 22, 2005 | 03:46 PM
Nice when it all goes back together , when i did mine i went for stainless steel bolts and nuts
Old Nov 25, 2005 | 12:12 PM
JamesS2RS's Avatar
JamesS2RS
twins where did you get your stainless steel nuts and bolts from???
