which parts are best
Old Oct 16, 2005 | 08:43 PM
c9sse's Avatar
c9sse
Default which parts are best
i have alot of parts kicking around the shed just wondered which ones to keep and which to get rid on a engine rebuild.
2wd and 4wd inlet manifold
2wd and 4 exhaust manifold
2wd and 4wd head
lots of sensors of both as well
which is best and why
cheers darren
Old Oct 16, 2005 | 09:15 PM
bud-weis's Avatar
bud-weis
Football Cwazy
to be honest it's all crap, if you like i'll come and take it away for you free of charge
Old Oct 16, 2005 | 11:53 PM
jon@work's Avatar
jon@work
If you mean plenum, keep the 4x4 one - slightly better design and flow distribution. Needs the 4x4 fuel rail and pressure regulator - does away with the poxy short bit of fuel line to the reg.
2wd exhaust manifold gives better torque.
I'd keep the 2wd head - gives slightly lower compression when compared to a similar thickness 4x4 head - unless it's an early 2-bolt thermostat housing head/small head bolt washer head, in which case, I'd keep the 4x4 head.
gambo08
Feb 4, 2016 10:49 PM
Oct 1, 2015 02:00 PM
fordrallycar
Sep 30, 2015 07:57 PM
Fordmad!
Sep 29, 2015 07:03 PM
