My car is really laggy
Old Oct 16, 2005 | 08:23 PM
richard_xr2i1800's Avatar
richard_xr2i1800
Default My car is really laggy
Hello i got a stage 3 saff with a t34 with .48 housing but it takes ages to get to full boost. but once on full boost it snaps your neck
Went to the 1/4 mile today and its a nightmare getting off the line. launched it with still no luck
Any ideas people
Rich
Old Oct 16, 2005 | 09:13 PM
bud-weis's Avatar
bud-weis
Football Cwazy
do you mean it takes ages before it starts to make positive boost, or once it makes boost it takes ages to reach maximum boost?? if it's the latter then try a -34 actuator
Old Oct 16, 2005 | 11:40 PM
jon@work's Avatar
jon@work
I had a T34 with a .48 housing on it - always took ages to spool up. Turned out the wastegate shaft was bent, so the wastegate was not seating/sealing properly. Still saw more than 30psi with it though, just took it's time getting there.
Old Oct 24, 2005 | 11:00 PM
Garnes Racing's Avatar
Garnes Racing
try a 82 housing and you will never say your t34 is laggy
Old Oct 25, 2005 | 08:56 PM
JamesH's Avatar
JamesH
Funny, yet not very helpful
Old Oct 25, 2005 | 09:04 PM
carl s's Avatar
carl s
mine doesnt seem too bad and ive got a .63
not sure if a -34 makes it any better
what boost you running and what times did you get
carl
Old Oct 25, 2005 | 11:03 PM
Garnes Racing
from 4500rpm it`s insane
Old Oct 26, 2005 | 08:17 AM
bezo's Avatar
bezo
powered by K26
Default Re: My car is really laggy
ive got the same sort of set up and mines fine.
spools up well, doesnt seem atall laggy, well maybe abit, but not like you describe????
Old Nov 6, 2005 | 12:58 PM
Mr C's Avatar
Mr C
is it low comp? my mates low comp with the same turbo drives like that too
Old Nov 6, 2005 | 02:13 PM
richard_xr2i1800
Yeah its running 7:2:1 comp , once on fully boost its a monster lol but its crap on the 1/4
rich
Old Nov 6, 2005 | 03:18 PM
rabmc's Avatar
rabmc
What actuators are you guys running with your t34`s
Old Nov 6, 2005 | 04:19 PM
Mr C's Avatar
Mr C
that was a good guess then, not a lot you can do but run BIG BOOST like its meant to and a turbo to suit or raise compression for better off boost power. You may be able to have more of the boost mapped in further down the revs to help illiminate some lag. I bet its fine between gears when on full boost though is it?
Old Nov 7, 2005 | 03:55 PM
Mad_Ad_300bhp's Avatar
Mad_Ad_300bhp
tighten the preload a touch on the actuator it makes a world of difference. The tighter it is the more response u will get mate. (obviouslly u will get a bit more boost but its worth it) When i put my -34 on it was not very tight at first and was ultra laggy but very smooth when it came on boost. After tightening the arm it become very snappy and back end happy
Old Nov 7, 2005 | 04:04 PM
Beach's Avatar
Beach
My saph's runnin low comp and a t34 with a .55 exhaust housing and a -34 and it not really that laggy at all.
To be honest mate id sugest getting it mapped and setup correctly rather that just trying to adjust preload on the actuator and stuff like that.
Old Nov 7, 2005 | 04:12 PM
Mad_Ad_300bhp
as above this is the best way to do things but just check that the arm is nice and tight as if it has been off the car for any reason or somebody has been messing with it then its not going to be doing its job properly......but be carefull.
btw can i ask what kind of actuator it is ?
Old Nov 7, 2005 | 04:16 PM
Mad_Ad_300bhp
https://passionford.com/forum/viewtopic.php?t=151577
check this first of all
Old Nov 7, 2005 | 05:16 PM
DamoM's Avatar
DamoM
When you say the car is laggy, when exactly do you start to see positive boost in 5th and when do you get maximum boost?
I have a T4 (no that is when you get to know the meaning of laggy!) and I get positive boost by 2800 rom and maximum (1.8 bar) at 4000 rpm. Car has 7.5:1 c/r and 435 bhp.
Old Nov 7, 2005 | 05:22 PM
Garnes Racing
whit 7.2 comp,bd14`s ,ported head and jenspeed(norwegian tuner)chip,670cc injectors,
netic super 60 ar82(largest t3 model) the boost start at 3500rpm,max boost at 4000rpm. whit stock cams max boost at 5000rpm.
Old Nov 7, 2005 | 05:30 PM
DamoM's Avatar
DamoM
That does sound a little laggy compared to mine, bearing in mind I have std cams......
Old Nov 7, 2005 | 09:29 PM
Garnes Racing
its not so bad really,was a big diffrens when I fitted the bd14`s.
rev limit is 7900rpm so it good on revs
Old Nov 15, 2005 | 09:19 PM
RobCarden's Avatar
RobCarden
358bhp
mines on std compression with a .63
i get full boost around 4kish with around 10 psi at just over 3k
Old Nov 15, 2005 | 09:46 PM
Garnes Racing
more tuning on the way now,820cc injectors,new chip,new intake whit 3 inc trottle,3 fuel pumps
hopeful we see 500+ on the dyno and maybe more....
(engine was on the rollers in 2wd cossie and gave 403.3 at the wheels whit std cams) sitts in 4x4 now
Old Nov 16, 2005 | 03:15 PM
jonathanpearson996's Avatar
jonathanpearson996
keep her laggin....then your laughin after
Old Nov 16, 2005 | 03:37 PM
Garnes Racing
Old Nov 18, 2005 | 04:32 PM
Gav Diamond's Avatar
Gav Diamond
Just seen this
I had a similar problem to this with my car the once.
Mine turned out to be that i wasn't getting full throttle.
Get someone to sit in your car and press accerator to the floor(engine turned off) and then see if it is opening the throttle fully in the engine bay.
Once mine had full throttle it was a totally different car to drive
Old Nov 19, 2005 | 06:39 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
ive got a t34 .48 and to be honest it aint very laggy at all! i was pleasantly surprised!
chop
Old Nov 19, 2005 | 12:49 PM
YBP's Avatar
YBP
My last engine ran a t34 with .48 and cutback turbinewheel on a portet head and balanced bottom end. It was just slightly more laggy than with the std t3 turbo.
Check your actuator.
How much pre tension do you have on it?
steerfromdarear
28
Jan 29, 2016 06:14 PM
Shows & Track Days
Aug 26, 2015 05:11 AM
Bailes1992
Aug 16, 2015 07:14 PM
Shows & Track Days
Aug 15, 2015 06:25 AM
