WHAT BEST PISTONS FOR 2L ZVH JUST MELTED No4 2day
whats the best pistons that i should put in my zvh just melted no4 standard ones today any idea on price thanx
Then its a case of whats your 'targeted power' which will determine bore size, piston diameter and what compression is best suited.
Will you need custom made pistons to suit planned diameter/compresson or will off the shelf pistons suffice?
As above have a look at whats available in the states you wont go wrong with JE or CP pistons
alternativly look at Mahle pistons for a Cav/Calibra Turbo.hth's & best of luck on getting your car back on the road
deathrider666
Sep 28, 2015 06:12 PM
