MK6 Escort - Zoo arms
Old Oct 16, 2005 | 04:28 PM
Paul_RS's Avatar
Paul_RS
Default MK6 Escort - Zoo arms
I know Zoo do a set of adjustable bottom arms that will suit my mk6 Rs 2000, but i was wondering what benefits these will have? Would they be harsh for everyday use as i think they are polybushed?
Sorta on this topic as well, but is Zoo able to produce a brake kit incorporating some type of AP calliper that will fit behind the standard mk6 RS 2000 alloy (15"x6") I know AP do a 295mm kit using off the shelf that will fit behind 15"x6" rims, however it will not fit mine as the spokes curve in where the meet the edge of the wheel.
AP kit details
CP5005-8
Competition Brake Kit for Ford Escort RS2000
Technical Information:
Caliper - CP5040 4 POT
Disc - CP5000-510G3, Ř295 x 25mm, 3 grooves, 24 Vane.
Pad - CP2340D51
Wheel 6J X 15" COMPOMOTIVE MTR/SP
Some pics of the wheel with standard brakes -
Any help with the brakes would be great as i view them as an important area of the car to upgrade.
Old Oct 16, 2005 | 06:20 PM
Paul_RS's Avatar
Paul_RS
bumpnesssss
Old Oct 16, 2005 | 09:47 PM
Paul_RS's Avatar
Paul_RS
flaps
Old Oct 16, 2005 | 11:03 PM
Paul_RS's Avatar
Paul_RS
opposite of down....
Old Oct 16, 2005 | 11:11 PM
CossieRep's Avatar
CossieRep
Would wheel spacers help at all?
Old Oct 16, 2005 | 11:15 PM
CozzyBrom's Avatar
CozzyBrom
transform front end turn in
front end handling
it wont squrm all over the road under hard braking
neva have to change bushes or rose joints eva again
as for the calipers if there room to offset the disc back and there are not lug mounted you should be fine
Old Oct 16, 2005 | 11:36 PM
Paul_RS's Avatar
Paul_RS
Thanks for the reply
How much are the arms? I take they fit straight on? In regards to the brakes, is it a case of someone having to look at them, before a definate answer can be given on what can or indeed cannot be fitted?
Old Oct 16, 2005 | 11:43 PM
CozzyBrom's Avatar
CozzyBrom
i would need to do some measurement's and look at the caliper you after to work out clearance on the wheel
as for the arms
they are Ł350 delivered
Old Oct 16, 2005 | 11:47 PM
Paul_RS's Avatar
Paul_RS
Thought that may be the case - i'm in NI
Deffo interested in getting the arms bought (probably after i buy some chrimbo prezzies ) I'll give you a ring when i've got the cash together and get them ordered up.
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
FlashRS
Sep 14, 2015 12:36 PM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
Bighandsuk
Sep 2, 2015 05:23 PM
