500cc inj = rich tickover @ 2.50ms inj time ?
Old Oct 16, 2005 | 01:02 PM
leecavturbo's Avatar
leecavturbo
Default 500cc inj = rich tickover @ 2.50ms inj time ?
running dta, have lowered the tickover injector time to 2.50ms which is the lowest i can go before it cuts out , but i am still rich with a lambda of 9 is it cus the size of the inj is opening with such a small amount of time but still letting loads of petrol through ?
Old Oct 16, 2005 | 01:19 PM
Rick's Avatar
Rick
u need to check it with a CO meter, as lambda at v low engine speeds wont always regsister the same CO
Old Oct 16, 2005 | 01:24 PM
ECU Monitor Enthusiast
A "lambda of 9" means nothing ?????????
do you mean AFR or lambda ???
If you mean 0.9 lambda then that is not that rich !!
If it is truly rich, you have at least one or more of the following problems...
1) fuel pressure too high
2) Injectors are not fit for purpose
3) cam overlap causing low manifold pressure
4) sequential injection - injectors in wrong firing order
Old Oct 16, 2005 | 03:28 PM
leecavturbo
yeah AFR , target is 13.5 ish , as i lower inj time the afr rises from about 9 to 10 , but as i go lower on inj time ,the car cuts out ?
Old Oct 16, 2005 | 03:33 PM
Confused !!
You say AFR 13.5 - I understand this.
But what does 9 to 10 mean ?
I reckon your injectors are not suitable for what you want them to do.
They may be good for power but idle will be a problem !
In this situation, you must either ...
1) accept a rich lumpy idle
2) lower the fuel pressure (which will reduce top end fuelling too !)
3) use a higher idle speed to keep injectors in usable working range.
Are you using grey injectors by any chance ?
Old Oct 16, 2005 | 06:31 PM
leecavturbo
Confused !!
afr of 9 rising to 10 when i lower inj time from 3ms to 2.50ms inj are msd 500 or 525cc's , tried 2bar fp , i can live with a luppy rich idle if its not detrimental to the engine, i.e flooding the cylinder with so much fuel it reduces the lubrication on the bores of the cylinder ? if that makes sense !
Old Oct 16, 2005 | 07:15 PM
GaryEvo's Avatar
GaryEvo
is it because the steps on the map are to big,
from 3ms to 2.5ms is a huge step for idle
Old Oct 16, 2005 | 07:50 PM
leecavturbo
fuel map
idle settings, but changing the target i.e 840rpm
it doesn't seem to control to that rpm?
Old Oct 16, 2005 | 10:13 PM
Sketch's Avatar
Sketch
Are you gonna rev the engine to 9000rpm??
If not, then you want to re-set some of the break points for down at the bottom end of the map perhaps?
Be interesting to see how this turns out as im about to start mapping my DTA on 437cc injectors in the next day or two
Old Oct 16, 2005 | 10:18 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
I'm not supprised at 2.5m/s at idle with an injector that size is this an 8 litre engine
Old Oct 16, 2005 | 10:22 PM
Sketch's Avatar
Sketch
at Tony
Old Oct 16, 2005 | 10:34 PM
leecavturbo
well it won't run with a lower inj time, and i need this size injector to make the power i want
Old Oct 17, 2005 | 09:22 AM
AlexF's Avatar
AlexF
Your options are:
1) Fit smaller injectors
2) live with it as it is!
3) find better injectors
Alex
Old Oct 17, 2005 | 09:28 AM
Stu @ M Developments's Avatar
PassionFords Creator
Originally Posted by J871yhk
Your options are:
Alex
4) Fit better ecu that will do less than 2.5ms. Thats shonky.
Old Oct 17, 2005 | 11:24 AM
AlexF's Avatar
AlexF
I thought he ment the engine would cut out with a pulse width less than 2.5 ms....
Alex
Old Oct 17, 2005 | 11:47 AM
Turbosystems
Super Moderator
map it properly
Old Oct 17, 2005 | 11:54 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Up the idle to 1100rpm.
Old Oct 17, 2005 | 12:10 PM
JesseT's Avatar
JesseT
Are you using one or two squirts per two engine revolutions? Is the management sequential or batch injecting? Also, surely the tuning resolution must be more accurate than 100 us?
Upto a point you could play with the ignition timing at idle to retard it a bit so you can idle with a higher map value. You can also try to lean it a bit at your idle speed and richen a bit just below your idle rpm, so if it tries to stall or run bad, then it will pick up again. Same with timing too. A rising rate fuel regulator will also improve the situation a little.
Old Oct 17, 2005 | 04:45 PM
leecavturbo
Your options are:
Alex
it will go lower , its a dta p8pro , you can map it stu if you can fit me in ? if ya fancy it serious request btw
Old Oct 18, 2005 | 12:11 AM
Lee, are you sure its not the ignition timing causing it to cut on lower fuelling, and like miker says, try a slightly higher idle at this stage, then work back to a lower idle later on once you have cracked it.
Old Oct 19, 2005 | 04:32 PM
leecavturbo
no not sure , i didn't mind having a play with a bit of fuel ratio's but timing if i fook it up could be Bad for the engine aye
xrmalin
Sep 13, 2015 06:52 PM
Adam Graham
Sep 6, 2015 06:04 AM
Shows & Track Days
Sep 4, 2015 07:16 AM
hopper350
Sep 4, 2015 12:53 AM
