warming engines up..
Old Oct 15, 2005 | 04:50 PM
morto's Avatar
morto
Default warming engines up..
hi all was just wondering what people think about the theory that its best to start your engine and drive off straight away?
as the most engine wear is from cold to the engines temp, so by driving off as soon as you start is better as it gets to operating temp quicker..
is this correct or not?
thanks
andy
Old Oct 15, 2005 | 04:53 PM
Graceland's Avatar
Graceland
Team HOTHOT!
i let my taxi warm up before i drive it - usually about 5 to 10 mins to get the coolant upto temp, then steady driving for 10 mins or so to get the oil to temp
the diesel shitter gets started and ragged from cold tho
Old Oct 15, 2005 | 04:56 PM
ive heard of peeps doing both some say its bad to let a cossie sit idleing i dunno i let mine warm up lol
Old Oct 15, 2005 | 04:57 PM
dave cos4x4's Avatar
dave cos4x4
i always let my cars warm up.
Deffo do not high rev one when still cold.
Let everything get hot before booting it.
Old Oct 15, 2005 | 04:58 PM
bud-weis's Avatar
bud-weis
Football Cwazy
i think it's just best to let the oil temps get to their normal level before driving hard, regardless of leaving it or driving it straight away, but as above my van gets ragged from cold
Old Oct 15, 2005 | 05:02 PM
Oranoco's Avatar
Oranoco
I just start up and drive. Do take it gentle though until the oil has had time to come up to temperature. Then it's rev limiter in every gear
Old Oct 15, 2005 | 05:08 PM
Graceland's Avatar
Graceland
Team HOTHOT!
general warmup procedure for my fiesta diesel rotbox
picture the situation
its 3am on a cold wet and windy morning, the temperature is 5 celcius and there is a nip in the air.
the key is inserted, the engine starts, i slowly reverse down the driveway onto the road.
once on the road, first gear is engaged and off i drive upto the speed limit, holding it in 1st gear as long as i can - why? because the fooking heaters are still blowing cold, but by the time i get to the end of the street, 800 yards away, they are blowing warm
Old Oct 15, 2005 | 05:39 PM
Red16's Avatar
Red16
my mate used to have one of those BMW Mini Cooper things, in his manual it said not to let the car warm up at idle
Old Oct 15, 2005 | 05:42 PM
DanRSturbo's Avatar
DanRSturbo
I start the RST up and drive it, slowly until warm. If idling, I rev it to 2k and leave it there for 5 - 10 mins or so I guess, then another 5 mins casual driving.
The fiesta get's ragged from any temp
Old Oct 15, 2005 | 05:54 PM
user 769729789's Avatar
user 769729789
Usually just turn it on and drive off, but as a rule of thumb i never go above 3000rpm untill the temp gauge is "halfway".
Just summit ive always done really
Old Oct 15, 2005 | 06:06 PM
Phil's Avatar
Phil
Jeebus
I've always heard it is best to drive it slowly and at fairly low revs until warm. If you let it idle up to temp then givew it death immediately you will kill a lot of gearboxes and diffs
Old Oct 15, 2005 | 06:12 PM
Mr Brannen's Avatar
Mr Brannen
Cossies just dont go well at all when cold, simple as that
Old Oct 15, 2005 | 06:17 PM
Alloy's Avatar
Alloy
The best thing to do is let the car idle for about two minute's to get some heat into the engine, then drive of slowly using a short shift method of changing gear until the car is at it's best operating temperature.
Old Oct 15, 2005 | 06:22 PM
dave cos4x4
quite a few people warming up before ragging off then.
Old Oct 15, 2005 | 06:24 PM
Ginge !'s Avatar
Ginge !
just finding my feet
thats what i got told by stul idle for 1 to 2 mins then drive gentle, leaving it idle is bad for oil presure
as i used to pop out start car and set turbo timer for 10 mins, pop back in and finish my Tea, when i heard the alarm going off then i pop out and the car was all warm including heaters
fook me did i use petroll that way though
leaving the car is the same, dont rag the car and leave idle, rag the car THEN drive gentle unltill the temps are normal then park and leave to idle for 2 mins
my cabrio gets started in gear and is going forwards before me finger is off the key
Old Oct 15, 2005 | 06:28 PM
John Laverick's Avatar
John Laverick
I give it 10-20 seconds on initial start up then drive below 3k for 10 minutes.
Old Oct 15, 2005 | 07:02 PM
mrviper's Avatar
mrviper
my zetec turbo gets driven through 30 mph zones all the way to work and cant see the point warming up because the engie isnt under any load
i just drive along in 4th followng all the other slow gits and just change the oil regular with some fully synthetic stuff
Old Oct 15, 2005 | 07:09 PM
Rhys's Avatar
Rhys
I start mine up and just drive slow until everythinis to opertating temp!! Then i still dont boot it for a while after just incase.
My cossie never seems happy when its cold anyway, very lathargic (sp).
Old Oct 15, 2005 | 10:36 PM
Jimboxr4x4's Avatar
Jimboxr4x4
I've found it takes about 25 - 30 minutes before the oil temp reaches over 80 degrees. In fact after 15 minutes driving it is just registering about 50 degrees C. (although Tim gauages are crap so this could be way out!)
Old Oct 15, 2005 | 10:40 PM
pollocks's Avatar
pollocks
turn key let it have a couple of minutes for oil to get rpund the engine fully n then drive steady till its warmed up
Old Oct 15, 2005 | 10:49 PM
Stu @ M Developments's Avatar
PassionFords Creator
Engines dont give a fook wether its hot or cold, they should drive and perform virtually the same.
Old Oct 15, 2005 | 11:07 PM
Rhys's Avatar
Rhys
mine seems a bit more lathargic Stu! Though it might be me being to much of a pussy with the throttle when its cold! And also i thing my slag of a taxi does like being woken up!
Old Oct 15, 2005 | 11:28 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
aluminium engines(blocks )dont like getting warmed up,in my wifes punto manual it says dont leave your car sitting ticking over for long as the block can warp,and yes its already done that,(warranty claim, its now fixed)!
maybe the BMW mini is the same,they go on fire tho instead!
Old Oct 16, 2005 | 12:26 AM
I just start my cars up and drive them, but i dont drive them very hard till they are warmed up.
I dont ever leave idling for a long period from cold though like it sounds like some people do.
Old Oct 16, 2005 | 12:34 AM
SS1's Avatar
SS1
no wonder the fuckin trains are always late ..
not that i use them by the way ..just throwing a spanner in the works
Old Oct 16, 2005 | 01:48 AM
Graceland's Avatar
Graceland
Team HOTHOT!
what the FUCK has my car got to do with trains? absolutely FUCKALL
Old Oct 16, 2005 | 02:00 AM
SS1's Avatar
SS1
the time the staff take to get to work
Old Oct 16, 2005 | 02:02 AM
SS1's Avatar
SS1
joke ..
well it sounded funny wtih 12 stellas inside me
Old Oct 16, 2005 | 05:04 AM
canuk's Avatar
canuk
The quicker the engine can warm up the better. Start up is the most criticle time for your engine and it's parts. So by driving it you warm it up faster and plus you save a bit on fuel.
Old Oct 16, 2005 | 08:00 AM
Matt's Avatar
Matt
i start up and drive off and keep it off boost until oil is to temp
engine might not but the map cares
Old Oct 16, 2005 | 08:27 AM
Mr Brannen's Avatar
Mr Brannen
________
Totally agree with Rhys, Stu if you are telling me that a Cossie engine runs as sweet when ice cold as they do when they are up to correct running temperatures then you are wrong matey ,. Understand you are a lot more experienced than me but you can not surely believe what you said there
Old Oct 16, 2005 | 08:39 AM
you are wrong matey
Ok, i bow to your greater knowledge of engines.
It must be crap being a new car salesman eh?
Every car you sell, thousands per year, and the owners all bring em back moaning every day that they dont run as well when cold, and you simply cant do anything about it.
Why would a COLD engine run worse than a hot one exactly? Give me your reasoning behind it instead of telling me i am wrong and rolling your eyes at me. Afford me the same respect i afford you and Educate me...
Old Oct 16, 2005 | 08:45 AM
Matt's Avatar
Matt
Why would a COLD engine run worse than a hot one exactly? Give me your reasoning behind it instead of telling me i am wrong. Educate me...
wouldnt run "worse", it would be told to run different though surely.........ect sensor related for one?
piston to bore clearance not taken up?.......when its cold and slapping wouldnt you get more blow by and less compression?
Old Oct 16, 2005 | 08:51 AM
Are you suggesting that if you did a cylinder leakage test on your cold YB that it would FAIL the test Matt? Of course it wouldnt. A totally wankered engine may well run worse cold due to lack of compression, but thats kind of irrelevant to teh topic IMO.
The fact is, the cold fuelling and spark tables in most YB engines out there are garbage and need a week or two's mapping to get them a bit more sensible. Or are you all going to tell me your parents BMW's etc all run like shit when cold as well? How about your dads rather sexy new M3 Matt? Other than its ECU induced cold rpm limiter, does it drive noticeably different cold to hot?
Old Oct 16, 2005 | 08:57 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
A standard cosworth mapped by ford ran perfic at all temperatures
Old Oct 16, 2005 | 09:01 AM
Matt's Avatar
Matt
Are you suggesting that if you did a cylinder leakage test on your cold YB that it would FAIL the test Matt? Of course it wouldnt. A totally wankered engine may well run worse cold due to lack of compression, but thats kind of irrelevant to the topic IMO.
wasnt suggesting anything of the sort, i was asking if you would get worse compression on a slapping cold yb thats all
ive only driven it once so cant comment on the m3 BUT i very much doubt its any different. on my my test run i did note that the m3 appeared to have a passenger scream "running in" at driver above 5k rev limiter
cassie's clio kangaroo's to fuck when thats cold so hers defo drives differently
Old Oct 16, 2005 | 09:11 AM
Turbosystems
Super Moderator
Matt you'll find that her Renault Clitorous has a fault
Old Oct 16, 2005 | 09:32 AM
Ginge !'s Avatar
Ginge !
so what stu is saying is that cossies need the same time spent on em like what ford ect do on new cars to get it perfect
supose the more tuned the engine the more acurate the tollerences are for the running
belive christian said he could map a car but only the general map, not the cold start map ect as that requires alot more skill/experience, though im sure hes able to do that now too
Old Oct 16, 2005 | 09:36 AM
Mr Brannen's Avatar
Mr Brannen
_________________
Yeah but only a handful of people have standard ones now mate, and they are getting on a bit,
Old Oct 16, 2005 | 09:37 AM
Mr Brannen's Avatar
Mr Brannen
standard ones apparently werent half the bother you get with stage 3?4 etc....see what Im getting at
