converting 2.9 xr4x4 to 24v cossie
can u use the sump from the 2.9 engine and bolt it straight onto the cossie lump and also will the cossie engine bolt straight onto the manual gearbox,would the flywheel and clutch work aswell,any help is much appreciated cheers
Also engine mounts off the 12v, arms and rubber bits
passenger side exhaust will bot up,driverside needs to be cut bodged and welded
powersteerings a combo of bothe 12v and 24v bits
Heres one i bodged earlier
[/quote]
Russ Payne
Sep 25, 2015 08:29 PM
