taking off air box
Old Oct 13, 2005 | 11:25 AM
sufsRS's Avatar
sufsRS
Default taking off air box
how hard is it to take off the air box where does it bolt on?
Old Oct 13, 2005 | 11:29 AM
zippyobrien's Avatar
zippyobrien
piece of cake mate. as you look at the air box, there is one bolt right at the front, and there is one on the back right hand corner. i think there 10mm bolts,
hope this helps.
Old Oct 13, 2005 | 01:09 PM
sufsRS's Avatar
sufsRS
cheers for that mate i thought it would be harder then that because it looks like the box goes under the fuel metering unit somehow on the top left corner???? cheers for tho
Old Oct 14, 2005 | 10:38 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
It kinda does: fits under a bracket. I fitted a load of washers same thickness as airbox so that I could tighten that bolt back down properly.
Old Oct 14, 2005 | 11:46 PM
sufsRS's Avatar
sufsRS
sorted m8 cheers was just a 10mil at front and 8mil alla key at back
CLIVE
Oct 2, 2015 12:58 PM
matman
Sep 9, 2015 05:45 PM
lee2cossies
Aug 26, 2015 10:04 PM
track.focus'd
Aug 12, 2015 05:53 PM
