S2 Slow Windows
Old Oct 12, 2005 | 09:50 PM
mark-rst's Avatar
mark-rst
Default S2 Slow Windows
As above, S2 electric windows are really slow..
Bad earth?
Where do i look?
Old Oct 12, 2005 | 10:00 PM
GrimmeRS2K's Avatar
GrimmeRS2K
check the wires what run through the door into the car, they can wear there causing the windows to run slower
Old Oct 12, 2005 | 10:39 PM
rs_daz's Avatar
rs_daz
There a pain int they lol
I greased my windows up which helped abit
Old Oct 12, 2005 | 10:45 PM
mark-rst's Avatar
mark-rst
Its not in my car but my mates and the passengers is soooo slow i'm gonna have a look at it
Should have keep fit windows like me *lol*
I'll try the grase thing and check the door wires...
Cheers guys
Old Oct 13, 2005 | 09:57 AM
JamesA_RST's Avatar
JamesA_RST
Ive got the same problem with mine, takes about half n hour for them to go up, and if you try doing both at once thats the end! they both stop!
Gona strip them both down when i get a chance, check the wires and get some silicon spray on the runners,
Old Oct 13, 2005 | 03:22 PM
adamS2RST's Avatar
adamS2RST
My old S2 used to do this, once the runners were greased up that helped a fair bit
Old Oct 13, 2005 | 07:46 PM
withamxr's Avatar
withamxr
mine are slow to. always assumed it was the motors.
Old Oct 13, 2005 | 07:56 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
mates mates,tek your panel off the door,librally spray with wd40,(cleaner)
use your windows up and down a few times,they will loosen up for sure,then use a wax spray grease on all the moving parts,(white lithium) from halfords and good car stores!
sorted ,
mine used to be sloooooow!
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
