What PSI do brakes use
Old Jul 5, 2004 | 02:51 PM
Ryan's Avatar
Ryan
Default What PSI do brakes use
as in general terms, what is the psi roughly, obivously the harder you brakes the more PSI is applied, but a general idea would be nice.
thanks
Old Jul 5, 2004 | 02:53 PM
SapphyMike's Avatar
SapphyMike
650,000,000,000,000,000,000,000,000 psi
Old Jul 5, 2004 | 02:59 PM
Ryan's Avatar
Ryan
Old Jul 5, 2004 | 03:00 PM
Ryan's Avatar
Ryan
i actually have no idea what psi they use, i mean is it
100psi?
1000psi?
10,000psi?
Old Jul 5, 2004 | 03:04 PM
SapphyMike's Avatar
SapphyMike
i imagine theres probably a pressure range, so much pressure to give so much pressure at the pad... i know it sounds daft, but i know that haynes manuals list this kind of info...if you have one lying around perhaps worth looking?
Old Jul 5, 2004 | 03:06 PM
Ryan's Avatar
Ryan
yeah will have a look cheers.
Old Jul 5, 2004 | 03:09 PM
foreigneRS's Avatar
foreigneRS
Testing the future
doesn't it give a maximum working pressure on the rubber hose?
must be reasonably high to require metal lines and special/braided hoses.
why the question?
it's possible to work it out if you need to or can be arsed. you have a pedal ratio where the force that you apply is multiplied, and then you have the area of the master cylinder piston so it's not too difficult.
Old Jul 5, 2004 | 03:13 PM
GARETH T's Avatar
GARETH T
i cant remember,,, ummm long time since school
Old Jul 5, 2004 | 05:05 PM
markk's Avatar
markk
generally a working pressure of around 2000psi iirc obviously varies !!
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
