doing power run now. NOW WITH POWER PLOT
Oct 12, 2005 | 10:05 AM
How to stop back wheels spining, 2 people in boot allready.
tire pressures?
Oct 12, 2005 | 10:07 AM
Use a proper rolling road and you will have no problems!
not easy to stop, try 3 people in boot!!
you could reduce the pressure a bit but not alot!!
Oct 12, 2005 | 10:12 AM
the rollers are a bit odd reads about 280 bhp at wheels and when hit main boost at 4500 rpm just spins.
Oct 12, 2005 | 10:23 AM
ok first power run done 2 peeps in back and 2 psi drop in tire pressure now time to advance timing
Oct 12, 2005 | 10:29 AM
What you testing ?
Steve.
Oct 12, 2005 | 10:30 AM
Quote:
I thought Nobles was ok it has a nice cool room
Oct 12, 2005 | 10:31 AM
Oct 12, 2005 | 10:34 AM
If the roller diameter is too small then you will end up with problems due to a small contact patch between tyre and rollers for instance.
Neil.
Oct 12, 2005 | 02:04 PM
i see
what do you think its a 24v TT runing 16psi. the advance was never completed as One turbo failed and the gearbox lunched its self
Oct 12, 2005 | 02:35 PM
bummer
putting more weight on the back end of a sierra does not help traction on a rolling road. all that you do is increase the negative camber and toe-in, and reduce the tyre's contact patch on the roller.
and a cool room does not necessarily make a good dyno room - one with sufficient airflow does.
Oct 12, 2005 | 03:17 PM
so gents what power, take a guess
Oct 12, 2005 | 03:19 PM
lowering the tire pressures help a lot foreihneRS, and The act temps started rising so the room was not working well
Oct 12, 2005 | 03:40 PM
Unlucky sounds like a unsuccesful day
Oct 12, 2005 | 04:13 PM
Oct 12, 2005 | 04:16 PM
Quote:
Neil, your powers of observation leave a lot to be desired
I'd say 300bhp @ wheels before turbo lunched itself.
Oct 12, 2005 | 04:28 PM
Acht its been a long day - some of us have to work, not ponce around trying to look pretty!
Oct 12, 2005 | 04:51 PM
Got the full spec of the engine ?
Also any pics ?
What box and turbos are you using ?
Steve.
Oct 12, 2005 | 05:40 PM
The settings of the RR should be able to be altered to decrease the amount of Wheelspin.
The Acceleration rate of the Rollers is set to load the car up, this can be increased so that the rollers have a better chance to keep up with higher powered cars. Well, on most RR's anyway. The consequence of this might be that there won't be enough resistance/load to allow the car to build full boost.
Oct 12, 2005 | 05:46 PM
take it to a dyna pack equiped place no problems with wheelspin then
Oct 12, 2005 | 07:53 PM
well mr rainbum and thanks to you and Phil
it made 460 bhp at 4900 rpm before it lunched it's self the one turbo siezed and the RR operator asked has a boost pipe droped off.
no shit
This car cossie 4I
Oct 12, 2005 | 07:54 PM
it was the one on the right if you must know
Oct 12, 2005 | 07:55 PM
Excellent mate
...Top Boss=top company,pleasure to be of help and service.
Oct 12, 2005 | 08:01 PM
Any other pics ?
Looks well clean
Oct 12, 2005 | 08:24 PM
there you go cossie 4I
Oct 12, 2005 | 08:55 PM
very nice!
big power at crazy low revs
Oct 12, 2005 | 09:02 PM
you should see the graf, I will scan it tommorow the massive drop off
Oct 12, 2005 | 09:17 PM
looks sweet, who needs YB
Oct 12, 2005 | 09:52 PM
Oct 12, 2005 | 10:05 PM
very good figures mate
shame bout turbo and box tho
would be good to see the graph.remember this car i think from a magazine a few years back im sure.always loved the colour.
Oct 12, 2005 | 10:07 PM
Oct 12, 2005 | 10:15 PM
Oct 12, 2005 | 10:21 PM
Oct 13, 2005 | 08:58 AM
I thought this car has a proper cossie shell ?
I think Fitz at Topboss owns it.
Steve.
Oct 13, 2005 | 09:44 AM
Looks lovely
Oct 13, 2005 | 10:15 AM
its a proper cossie shell Cossie4i
Oct 13, 2005 | 10:21 AM
quality!! 460 is a nice figure the car looks the nuts too
