S2 Underside Restoration?
How easy is it to paint the under side of a s2, as i was thinking of taking a week of work the end of this month and giving it a good go. What exactly is involved?
All depends how far you want to take it ,i would say in one week you would be pushing it ,better to do a section at a time if you cant do it all at once ,have a look on my thread (Click on my sig )the underside on mine took two people 8hours a day 3 weeks to complete from the dash backwards ,front end took 2 months,best to strip all the suspension and tank out aswell
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
as above,once all the crap is off,and new parts(where needed,i.e.shackles),
its a case of a good wire brushing,and any welding needing done,then a good couple of coats of your favourite colour ,
mines juss done,i have a black turbs ,my underside is now silver!
all the new stuff is ready for the fookin salty roads to fuck it up!
gonna librally coat it in AC-40,aircraft preservative!
it started out as a general tidyup, but new parts soon started arriving
If you want inspiration tho, click on the Twin's restoration thread
Are you keeping it then Adam?
I am in process of doing a complete restoration I started this project about 3 months ago I have spent about 4-5 weeks prepare and painting the underside and I had a week off to put it back together
. It is not a hard job and everything is quite straight forward but I would personal label every thing you take off. I would replace the bushes, fuel pump assembly while your under there it a very very messy job take you time and make it look the plums otherwise your just be under there again in few months.
guys,read my thread on s2 (akito-man)
theres things you need to check,the brake valve switches,on the two i had ,believe this,BOTH had gravel particles contaminating/blocking the movement on the drivers side,in exactly the same place/way,rendering their affectivness,making that side redundant!IRONIC!,CHECK YOURS!
but see what you can get at,my paint took 1 week 2coats,after all the prep was done,but im a painter by trade!,thats workin in your own time,after days work,outside on the drive
you get it everywhere,wear gloves
is there any company out there that would take on doin an under body restoration?i want one done to mines but i aint got a hydraulic ramp to get under the car or i would give it a good shot myself
yeh mate i saw that one in performance ford mag.only problem is im up in scotland.its a company im looking for like that up here.that would be perfect.i would do it maself but ive lost all my kuckles lying under cars and would prefer to leave this to someone with ramps
SMILER258
Sep 28, 2015 09:04 AM
