Where does this hose go??????
Old Oct 11, 2005 | 06:48 PM
Mark 3D's Avatar
Mark 3D
Moderator
Default Where does this hose go??????
Just bought some Roose Sport water and Anc hoses and am left with this one????
anyone tell me where it goes?
Cheers,
Mark
Old Oct 11, 2005 | 06:49 PM
DAN P's Avatar
DAN P
swirl pot ???
Old Oct 11, 2005 | 06:50 PM
Mark 3D's Avatar
Mark 3D
Moderator
nope
Old Oct 11, 2005 | 06:58 PM
dave cos4x4's Avatar
dave cos4x4
think its off the radiator.
What car, a cossie.
Old Oct 11, 2005 | 06:59 PM
DaveEscos's Avatar
DaveEscos
water pump to lower rad hose
Old Oct 11, 2005 | 07:00 PM
SteveB's Avatar
SteveB
1 end to the oil warmer where the oil filter screws on (some call it the oil cooler but it actually a warmer) and the other end to the back of the head by the blue water temp sensor for the ECU
Old Oct 11, 2005 | 07:03 PM
DaveEscos's Avatar
DaveEscos
or that!
Old Oct 11, 2005 | 07:10 PM
dave cos4x4
Old Oct 11, 2005 | 07:13 PM
Mark 3D's Avatar
Mark 3D
Moderator
cheers guys i shall go have a look lol
Old Oct 11, 2005 | 07:52 PM
mk2rstaff's Avatar
mk2rstaff
pain to get into that one did it on mine fiddly as fook
Old Oct 11, 2005 | 08:16 PM
Mark 3D's Avatar
Mark 3D
Moderator
Well...............I still cant see where it goes?????? cant work out where you mean?
Old Oct 11, 2005 | 08:20 PM
SteveB's Avatar
SteveB
Under the inlet manifold
Old Oct 11, 2005 | 08:25 PM
SteveB's Avatar
SteveB
If you look at my oil filter...... there sandwich plate for the mocal oil cooler is there... usually there is an oil warmer there in its place 1 pipe goes into it from the heater matrix... then the pipe comes out and goes to the rear of the head just behind the inlet manifold this is the pipe that you have pictured... a bastid to change and all I can say is good luck
Old Oct 11, 2005 | 08:56 PM
Mark 3D's Avatar
Mark 3D
Moderator
Im still confused any way u could mark on there where it goes?
Old Oct 11, 2005 | 09:07 PM
mk2rstaff's Avatar
mk2rstaff
if you stand in front of the car look down the right hand side of the engine, go all the way to the back and look between the bulk head and the rocker cover about 2 inches down, thats the back end of the pipe, the front is just in front of steve b's right hand engine mount, aboove the iol filter hope this helps its a hand touch feel to find it under the inlet
Old Oct 11, 2005 | 09:51 PM
Yep, runs from the cambelt end of the engine to the back along the passenger side under the inlet, from the heat exhanger (it both warms the oil up on initial start up AND cools it down under heavy loads so people who say both are right!)
Old Oct 11, 2005 | 09:59 PM
Mark 3D's Avatar
Mark 3D
Moderator
Originally Posted by mk2rstaff
if you stand in front of the car look down the right hand side of the engine, go all the way to the back and look between the bulk head and the rocker cover about 2 inches down, thats the back end of the pipe, the front is just in front of Steve b's right hand engine mount, aboove the iol filter hope this helps its a hand touch feel to find it under the inlet
Shit Hot!! yep found it now, looks like it will be fun to change lol!!
thanks for all your help guys!!
Old Oct 11, 2005 | 10:31 PM
RichardPON's Avatar
RichardPON
That one is a cooont to do
gcfcos
59
Oct 6, 2015 05:04 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Russ Payne
Sep 25, 2015 08:29 PM
