Changing S1 radiator.
Old Oct 11, 2005 | 12:14 PM
c5tto's Avatar
c5tto
Default Changing S1 radiator.
Does anyone know how much needs to be stripped to replace radiator on a S1 RS turbo. looks like the turbo and possibly manifold need removed?
Old Oct 11, 2005 | 03:46 PM
S1 JOHN's Avatar
S1 JOHN
i think you can get it out without ive just took mine out but i have a grs intercooler so the rad is slightly further back and it just scraped on the turbo , i noticed on mine its more the actuator bracket that it catches on you will find out when its half way out hope this helps
Old Oct 11, 2005 | 05:22 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
it will come out with the manifold on as said, i fitted, removed and re-fited a new one with it all in place, think i removed the IC so i could slide it over and up at an angle if you get me. will chaffe a little but not seriously if your carefull.
Nov 1, 2015 06:53 PM
dojj
Sep 29, 2015 10:32 PM
rsguy
44
Sep 29, 2015 03:29 PM
marky_g
Sep 12, 2015 04:26 PM
