FAO anyone with a s2 rear disk conversion....
Old Oct 10, 2005 | 06:35 PM
Moondust_crust's Avatar
Moondust_crust
Default FAO anyone with a s2 rear disk conversion....
hi im looking to put a disk conversion on the back of my cabby, just need to know in what order do u assemble things onto the rear hubs?
do i need to keep the 4 bolts that you bolt the rear drums onto the hub with?
no idea where the wheel bearings go either
any help anyone can provide will be very usefull.
Old Oct 10, 2005 | 06:48 PM
xr4x4rs's Avatar
xr4x4rs
basically you will need to assemble in this order
put caliper bracket on where drum back plate used to be
then hub on
disc
caliper and pads
handbrake cable and brake lines
the bolts i got with mine were the heads have been machined down as the bracket is thicker than the deum plate so the hub would catch the bracket bolts
also what brake lines are you using as the originals will be to short
Old Oct 10, 2005 | 07:03 PM
adamS2RST's Avatar
adamS2RST
Interesting as I had this exact same problem too
Old Oct 10, 2005 | 07:11 PM
Moondust_crust
have you got any pics of your cus im not sure exactly what you mean
to be honest i aint got a clue where to start
anyone do a kit?
many thanx mark.
Old Oct 10, 2005 | 07:20 PM
adamS2RST's Avatar
adamS2RST
Yes, check out my resto thread page 4: https://passionford.com/forum/viewto...=asc&start=120
See if that helps you out, and I got my kit from Brom @ Zoo motorsport.
Old Oct 10, 2005 | 07:49 PM
Moondust_crust
ahh had a look mate and that makes it alot clearer, so the bracket goes on the hub first and bolts to the hub where the backplate of the drum used to be ,
then the disk and caliper?
then the wheel bearing hub nut and cover?
adam your probly the best person to ask cus you have put one together.
how much did the kit cost you and what size is it? many thanx mark.
Old Oct 10, 2005 | 07:53 PM
adamS2RST's Avatar
adamS2RST
Hmm...iirc the kit was Ł250, that was with second hand blasted and painted calipers
Have a look here: www.zoomotorsport.co.uk
Old Oct 10, 2005 | 08:01 PM
Al Bags's Avatar
Al Bags
Excellent pics and advice here .. http://www.zetec-turbo.co.uk/
on RichM's pages, plus click the link at the bottom of that page, too!
Al.
Old Oct 10, 2005 | 08:15 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Is there much point in a rear disc conversion? or are you lot just show offs
Old Oct 10, 2005 | 08:24 PM
Moondust_crust
just show offs
Old Oct 10, 2005 | 08:32 PM
adamS2RST's Avatar
adamS2RST
Shut up Dave Go pass your test
Old Oct 10, 2005 | 08:33 PM
vroooom ptssssh
It Wasnt Me!
Posing bastid
Old Oct 10, 2005 | 08:37 PM
adamS2RST's Avatar
adamS2RST
Old Oct 10, 2005 | 10:11 PM
richm's Avatar
richm
Al.
subsequently redesigned the brackets slightly to use 8mm bolts to hold the brackets, which avoids drilling the hub upright at all; and dual fixing holes for the caliper to allow fitment of either cossie discs or the slightly smaller, cheaper, (and in my experience more suitable for this application, giving a better front/rear balance) mainstream Sierra/XR discs.
155lee
Sep 6, 2016 11:10 AM
yatta
May 21, 2016 10:31 PM
The Enigma
Sep 12, 2015 10:12 PM
cossirob
Sep 3, 2015 09:17 PM
