Best way of removing opening rear quarter windows on a Escos
Old Oct 10, 2005 | 06:15 PM
TrevCos's Avatar
TrevCos
Default Best way of removing opening rear quarter windows on a Escos
Anyone got a good method? I'm trying to remove this tinting film and got most of it off, but can't get off the bits round the three mounting points, so I need to take them off.
Old Oct 10, 2005 | 07:51 PM
bluescortcossie's Avatar
bluescortcossie
only thing i can suggest is not to drop them ! ! !
get one of them dent puller things for a couple of quid and use it too hold the glass while a mate undoes the bolts
Old Oct 10, 2005 | 08:41 PM
Glenn5's Avatar
Glenn5
remove seatbelt top bolts and remove b pillar trim you will see the 2 screws for the hinges dont remove them yet then at rear of window either punch out roll pin on hinge usually siezed or pop black cap off outside window tape around nut mole grips on nut and un screw get sum 1 to hold window in place undo 2 screws on hinges and remove then polish up window apeture and clean window seal aswell
Old Oct 10, 2005 | 08:47 PM
TrevCos's Avatar
TrevCos
Thanks for that Glenn, are you saying remove the screws on the brackets on the front mounts rather than remove the two bolts that go through the window, because I think I've done this before on another car and then not been able to put the screw back in because something fell down inside the pillar.
Old Oct 10, 2005 | 08:52 PM
Glenn5's Avatar
Glenn5
yes remove the screws m8 there captive nuts in the pillar nothing will drop
Old Oct 10, 2005 | 09:11 PM
GOT2BZETEC's Avatar
GOT2BZETEC
Hammer
Oct 9, 2015 07:38 PM
Aug 29, 2015 08:16 PM
track.focus'd
Aug 12, 2015 05:53 PM
gordyshreds
20
Aug 10, 2015 02:59 PM
paceo
12
Aug 4, 2015 08:50 PM
