What would cause....
An actuator to snap like this.....its not even a year old yet btw was new when i had it set up when i got the car
I just want to know for info more than anything, anything that breaks i just get fixed lol...without actually knowing why it broke in the first place...yep i am wierd lol...sorry i just like to know these things...
Kim...someone hacksawing it would cause that
dave stop being a tosser and covering for your best mate
What strikes me is Eagle Systems is coming on at the EXACT times as Glass Eye did
...I wont stop not even for the crooked cops.
Kimmy......That turbo damper is bolloxed hunny by the look of it,hence the manifold bolts loosening/damper snapping etc.........
Cossies suffer terrible vibration through the exhaust manifold(2wd worse than 4x4),Either get a rebuild kit for your damper and set it up right or do what i did and get a proper RS 500 damper kit for it.....(GGR Do em at a very reasonable price)
CheeRS.......Rob...
CheeRS.......Rob...
Cheers hunni...how much am i looking at roughly??
I need to take the turbo off to get it rebuilt so may as well do all the rest at the same time....cheers hun much appreciated
Brand new complete RS500 damper with mounting block is Ł95.00 at GGR......An absolute steal.....
They are the only damper that work properly imo(unless you get a NMS trelliss frame..
Should cure all your problems.....
)Should cure all your problems.....
