Perspex welding - Anyone know where?
I had the address of a registered/certified Chloroform perspex welding firm but sadly lost it and desperately need the address of one. There are only a handful in the country as its very specialised.
NB, Chloroform perspex welding is completely invisable and used in commercial display manufacture etc. I am wanting the trip reset button hole in my instrument binnacle "glass" welding up btw.
Cam
Cam
what about http://www.displaysense.co.uk.
not sure if they can help but says they make dislpay stands etc to order so im sure they could help you out
It cannot be too specialised as I used to do cloroform perspex welding in school, you just clean the mating surfaces then use an eye dropper to apply a thin film to both surfaces then mate and hold until set, the cloroform evaporates leaving a clear strong bond
You can probably get a bottle from the chemist, although you may have to prove that you dont have ulterior motives for it
