What turbo will fit my Mk4 Rs turbo
Old Oct 8, 2005 | 11:43 PM
Mr RS's Avatar
Mr RS
Default What turbo will fit my Mk4 Rs turbo
I had a stage two turbo on but as most of you know they get very hot. Mine got so hot that I cracked the housing, so need new turbo. Was wondering if a cos turbo will go on? if so how. cheers for any help
Rob
Old Oct 9, 2005 | 12:22 AM
CasperR's Avatar
CasperR
Why not get the turbo rebuilt?
You can use a 4x4 cossie turbo but you will have to spin the housings to get it to fit and you will need a custom downpipe.
Old Oct 9, 2005 | 08:45 AM
Dan's Avatar
Dan
Cossie turbo will involve a bit more work from what I hear but can now be done to good effect, T34's go well on 1600cvh's at the moment!
Old Oct 9, 2005 | 09:00 AM
James Raby's Avatar
James Raby
T34 only on a high spec engine, or it's too laggy and plain shit basically
4x4 turbos go on easy enough, just get a cossie downpipe and weld it on to current system
As for cracking th housing, they ALL do that
Old Oct 9, 2005 | 10:55 AM
addiction's Avatar
addiction
i've been running a Turbo Technics stage 2 turbo for the last 2 years, it doesnt get too hot and works fine,no problems at all!!
EoinXR3
Sep 7, 2015 05:44 AM
jaimesdna
Aug 25, 2015 06:59 AM
A.t.p
Aug 15, 2015 11:37 AM
Dr. Ickxs
Aug 15, 2015 11:34 AM
