efi conversion on mfi rst
Oct 8, 2005 | 08:12 PM
do u have to change the fuel tank and pump or can u use the external pump and tank
Oct 8, 2005 | 08:13 PM
you are better off using the seperate pump and tank
Oct 8, 2005 | 08:16 PM
what do u do about the pressure difference though
Oct 8, 2005 | 08:18 PM
eh ????
i let the fuel presure reg deal with problem, i just drive the fooking thing
the erst fuel pump is better anyway and a cossie one is a straight fit
Oct 8, 2005 | 08:23 PM
i was told the return wouldnt be up to the job this obviousy isnt true then
Oct 8, 2005 | 08:38 PM
is this a erst where talking about or a carb fed car
as a xr2 needs the fuel tank modding as he fuel return aint man enough
on a erst its more than fine, christian and beccys is living proof
Oct 8, 2005 | 08:42 PM
its an rst car but im going 2.1 zvh with efi and 803s with a fully mappable chip will it be ok
Oct 8, 2005 | 08:48 PM
yes, cossie lines are thesame size
but a cvh requires alot of fuel
why niot go full zetec if ya going zvh/efi ????
mk3ste
Oct 17, 2021 10:09 AM
A.t.p
Oct 23, 2015 07:54 PM
A.t.p
Sep 29, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
