Massive big up to Mark @ MAD
Got in the evo started it up & the revs shot up to 3k
Couldnt understand it as i'd only just drove it an hour earlier & everything was ok
Anyway, had a look at all the usual things but couldnt figure it out!
SO....................
Got on the phone to Mark Shead & he knew what it was straight away & talked me through the re-setting procedure ................... SORTED
Mark, thanks again you are the man!
i dont know you, never met you, yet i seem to have gotten under your skin ?
chill phil and stop smoking the weed, or perhaps the gas from your ohlins is leaking into your car and you are breathing it in causing these dillusional outbursts.
