cvh block bore
Old Oct 7, 2005 | 03:37 PM
fredy's Avatar
fredy
Default cvh block bore
hi to all i am bouilding my engine now i would like to know if a 81mm bore the block will resist 2 bar of boost
regards
freddy
Old Oct 7, 2005 | 04:33 PM
GrimmeRS2K's Avatar
GrimmeRS2K
i should think so, people run close to 2bar on here
Old Oct 7, 2005 | 04:39 PM
mark-rst's Avatar
mark-rst
I run 2 bar on 81.5mm bores
Old Oct 7, 2005 | 05:45 PM
rswoza's Avatar
rswoza
28 psi of boost approx?
Old Oct 7, 2005 | 05:46 PM
mark-rst's Avatar
mark-rst
Yeah, 14.4 psi to 1 bar
Old Oct 7, 2005 | 05:51 PM
rswoza's Avatar
rswoza
thats alot of boost, how long u ran it like that for? any fueling mods? just interested as my tuner set my car at a max of 17 psi for reliablity but its been turned down to 12-13 and produces 200 bhp
Old Oct 7, 2005 | 05:57 PM
mark-rst's Avatar
mark-rst
its been on that boost for over 6 months with no troubles. I'm running low comp bottom end and the fueling is still KE Jet
Old Oct 7, 2005 | 06:04 PM
GrimmeRS2K's Avatar
GrimmeRS2K
thats alot for 12psi, u must extensive headwork!
Old Oct 7, 2005 | 07:29 PM
rswoza's Avatar
rswoza
not realy mate, 10000 miles on a new rebuild .5 over bore, reconned head by my tuner,chipped,camed, big intercooler,hybrid s2 water cooled turbo... thats it realy, just well set up like all the my cars have been in the past.
Old Oct 8, 2005 | 12:48 PM
fredy's Avatar
fredy
Default bore
thank for all replays can someone tell me what turbo will be good for 2 bar and what A/R and trim?
Old Oct 8, 2005 | 12:56 PM
CasperR's Avatar
CasperR
4x4 cossie turbo, kinda the same as a stg 3 rst T3, but the stg3 should have cutback blades and 360 bearing.
Old Oct 8, 2005 | 11:44 PM
ON-UJAH's Avatar
ON-UJAH
You need an adaptor to runn a Cossie style turbo...
Your not building the ZVH anymore then?
Old Oct 10, 2005 | 12:20 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Personally I would like my block walls as thick as possible on a high power CVH.
Old Oct 10, 2005 | 10:13 PM
Rick's Avatar
Rick
A T34 with a 0.48 housing would work well if ur head has been ported.
Old Oct 14, 2005 | 07:39 AM
JesseT's Avatar
JesseT
You might want to look in the GT28 range for a bit more modern turbos.
Old Oct 14, 2005 | 01:38 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
14.5037738psi
Old Oct 14, 2005 | 05:32 PM
mark-rst's Avatar
mark-rst
14.5037738psi
That means i'm running a little more boost than i thought
Old Oct 14, 2005 | 10:55 PM
fredy's Avatar
fredy
Default turbo
thanks for all replays first i ordered 80.5mm piston bore and i think that would be safe. also i think i will go with the GT28rs for my setup
gcfcos
59
Oct 6, 2015 05:04 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
20/20 vision
Sep 28, 2015 03:03 PM
