General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
I've got an oil cooler, but there is no indication as to what the boss/connection type is apart from a "6" etched into each boss.
The diameter of the boss (excluding the thread) is 19/20mm (including the thread 21/22mm) which i have been told is near enough bang on 1/2inch BSP. The connections are corvexed if that helps.
has the oil cooler inlets got the plastic covers still on them? if yes take one off and have a look inside the cover.thread size is normally stamped inside.
It may be then that the threads are a std Dash -6 jic, (jic is a convex 37 degree dome ) , the outside of a dash 6 fitting is roughly 20mm so that could be it . As for the thread i think its 9/16 unf x6 but you wont need that . Its probably a bit small for an engine oil cooler if it is dash 6 , its more usual to be an 8 or 10 size.
has the oil cooler inlets got the plastic covers still on them? if yes take one off and have a look inside the cover.thread size is normally stamped inside. banana_dance.gif
FPMSL!!!!!!!!!!!!! so it does.......... and 5/8inch??
