mfi to efi help please.
Old Oct 3, 2005 | 05:09 PM
BRIGSPORT's Avatar
BRIGSPORT
UNAUTHORISED DEVELOPMENTS
Default mfi to efi help please.
I am about to embark on an mfi to efi conversion on my s2. I have gathered most of the bits required,but my main problem is with the bottom end and the cps.
Is it straight forward to drill a hole in my original block for the cps?
If not, will an xr2i block be ok as a base,obviously with the pistons etc. changed.
I know a frst bottom end is the answer,but i want to make the best use of what i have.
Old Oct 4, 2005 | 11:30 AM
JesseT's Avatar
JesseT
Yes, it's straight forward to drill the 30mm hole. Just drill it to the correct position. It's ok to use a XR2i block too with changing the pistons. Then you will need to drill the oil return to the side of the block. The place is there in the block, just needs to be drilled out. I'd say drilling the 30mm hole is far easier if you have a suitable drill bit. A "Christmas tree" like this with a 30m final diameter will be ideal for the job if available.
Old Oct 4, 2005 | 05:38 PM
BRIGSPORT's Avatar
BRIGSPORT
Where will i find the dimensions for the hole,and also the settings for what distance the sensor should be from the flywheel?
steve.rst
Mar 15, 2016 08:01 AM
tankybaby66
Feb 6, 2016 02:24 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
dms04
Sep 11, 2015 01:57 PM
stevierob
Sep 7, 2015 07:09 PM
