Xr2i running prob
Old Oct 2, 2005 | 06:10 PM
Toe Knee's Avatar
Toe Knee
Default Xr2i running prob
Whats this on an 8v Xr2i?!?!?!
Unfortunatly dont know fook all about em
Looks like an ISCV to me but just wanted to make sure, car wont run from cold unless its unplugged (obviously have to keep the revs up or it'll stall) But then when u blip it unless the white sensor on the inlet is unplugged it stutters at about 2k revs...................
Any ideas to why?!?!
Old Oct 2, 2005 | 06:11 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
i think some pics may help here
Old Oct 2, 2005 | 06:13 PM
Toe Knee's Avatar
Toe Knee
errrr yea was just getting to that
Old Oct 2, 2005 | 06:18 PM
Rab's Avatar
Rab
Fucking superstar........
Thats the Weber type ISCV. The hitatchi one is attactched to the manifold.
Old Oct 2, 2005 | 06:22 PM
Toe Knee's Avatar
Toe Knee
Ah right thought so mate cheers, so would that beeing fooked cause it to run shit?!
Know on the cossie it would just normally cause probs idleing till its warm
But as i say unless the white one on the inlet is unplugged aswell it still runs shit So bit confused as to what it could be?!
Also wheres the map sensors on these things?! cos a mate thought it could be that causing the prob???
Old Oct 2, 2005 | 06:30 PM
Toe Knee's Avatar
Toe Knee
Thats the white sensor im on about btw!
Old Oct 2, 2005 | 06:33 PM
Rab's Avatar
Rab
Thats the air temp sensor. The map sensor is in the top right of the above photo, just half of it in shot. When is it running shit m8? All the time?
Old Oct 2, 2005 | 06:41 PM
Toe Knee's Avatar
Toe Knee
Yea mate all the time, started ages ago but when i got the cossie it kinda got left on the drive till now
baically, was driving down the motor way and it lost power, then pulled over and it died and wouldnt run.
From cold now, you'll crank it over and it wont do anything, unplug the white sensor and it''ll occasionlly try to turn over but wont for a long time, then eventually does but runs shit and tries to stall, and as i say there sa miss at about 2k revs.
Found out yesterday when i had a play that if both air temp and ISCV are disconnected will start and rev fine unless u dont hold the revs then will stall, even when warm
Old Oct 2, 2005 | 06:46 PM
andyhardy's Avatar
andyhardy
See if you can try someone else's MAP sensor - mine went on an old XR2i I had years ago causing very similar symptoms to what you're suffering.
Cheers,
Andy
Old Oct 2, 2005 | 06:52 PM
Rab's Avatar
Rab
That sounds like the MAP sensor is gubbed. Try another MAP sensor, see if it helps.
Old Oct 2, 2005 | 06:54 PM
Toe Knee's Avatar
Toe Knee
Cheers lads, much apreciated Should have done it along time ago really but been a lazy fucker
Come 2 think of it, when the map sensor went on my old cossie it would run shit and wouldnt idle and stall, only just remember doh!!!
Cheers again will give it a go
Old Oct 5, 2005 | 08:00 PM
Toe Knee's Avatar
Toe Knee
Bttt............
Rang a ford garage today and aparently its called an isis sensor or something gay like that (wasnt called a map sensor on the early 2i's?!)
well basically its aŁ130 odd new
Like fuck am i payin that
Gonna go 2 a couple breakers see if any have some, but were they used on any other cars like the 1.6 EFi escorts etc around the same reg?!?!
Would make finding 1 easier if im not confined 2 just lookin for a 2i!!!
Cheers again
Old Oct 22, 2005 | 05:35 PM
Toe Knee's Avatar
Toe Knee
Right baicsally, got 2 map sensors from a breakers yard and its still doing it with both
Wont even try and start if u just crank it but with the ISCV unplugged it'll try 2 turn over but wont, if u give it slight revs then it almost starts then dies!! had it rev for a few seconds a couple of times then again dies moreso when u press the throtle
Any other ideas?! thought ECU but wont know till i try another one!
Old Oct 22, 2005 | 07:14 PM
Toe Knee's Avatar
Toe Knee
bttt
Old Oct 22, 2005 | 08:46 PM
MikeyXR2i's Avatar
MikeyXR2i
Might be Throttle position sensor knackered. Id even try another coil pack on it. Thats the early type ISCV you have to which requires cleaning quite regular, the later type was maintence free.
`spotty
Sep 25, 2015 11:41 PM
dombanks
Sep 21, 2015 08:38 PM
gcfcos
88
Sep 15, 2015 03:48 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
