sump gasket, any make good enough ??
after almost using a felpro head gasket i went out and got a ford one, what about sump gaskets though ?
does the same rule apply here , should i just get a ford one, or is there better available ? ?
cheers guys .....
cheers guys .....
interesting topic!
i have recently had a leaking sump gasket.
local garage went with a motorfactor part which still leaked so i bought a ford one and got them to fit it and it seems to have done the trick.
Finis:...........Item..................Price
1645268......Sump.................£94.19
1602149.....Gasket: Oil P.......£2.18 (Two part rubber end seal)
1602148.....Gasket: Oil P.......£2.18 (2nd part)
6101950.....Gasket................£2.44 (Cork: one side)
6101951.....Gasket................£3.23 (Cork: other side)
Total inc VAT: £125
Total inc VAT: £125
Originally Posted by rs shawn
I was advised to get a Ford cork one. Not fitted it yet tho...
Waiting for next oil change: got new sump as well
I have and recently bought a new rubber Ford one - £19 it was
I need it as taking sump off etc - they last for 13 years if fitted properly which most people can't seem to do so well
There is a technique to fitting cork gaskets. Golden rule is NO SEALER unless absolutely nessesary. On a sump, fitting the gasket is a little difficult unless you use sealer to hold it in place though. If you use sealer, this allows the gasket to be squashed too easily and it slides out of the sides of the sump and splits as you tighten it.
All sealing surfaces need to be clean, dry and oil free (completely) and then you have a chance of them sealing.
track.focus'd
Aug 12, 2015 05:53 PM
lockie
Jul 31, 2015 10:03 PM
