205 block
As far as I know there is no difference other than that cosworth handpicked the Ford 205 blocks based on the tolerences that each individual block had been machined to.
hence a cossie 205 block should have tighter tolerences than a Ford one.
hope that helps
hope that helps
they were selected because of there cylinder wall thickness......!
if you look where the dizzy goes on a 205 block there is a 4 digit number stamped into the block, each number corresponds with each cylinder and they will be all 2's or 3's on a cossie block(or on a block that could have been selected) but i cannot remember if they are 3's or 2's
HTH
Pugo
HTH
Pugo
