2wd brakes on an escort
Hello im getting some new brakes and might fit my old ones to my bro's escort turbo, do they go straight on and if not whats needed
Rich
Rich
You need:~
2x 4wd cossie front callipers
2x 2wd cossie front discs
4x 1mm washers/shims
2x extended braided brake lines
Oh and don't forget ya pads
I've got the 2wd 4pots on my series 1.
You have to machine 4mm off the inside face of the caliper and put a 90 deg union or banjo union connector on them to miss the drive shaft.
I've tarox 2wd discs and pads and they're unreal! Can just about get back end in the air
Be warned: these DO NOT fit behind the standard wheels because the calipers are just too big.
i got 2wd discs with the standard s2 calipers with a bracket to hold the caliper, dont know where the bracket was bought though as they were on a car that i stripped, they work alot bettr then standard size though
have got 2wd discs and rst calipers on mine, black diamond discs mintex 1155 race pads, bit noisey but stops on a sixpence. you need disks and mounting brackets, you can get the brackets from hi-spec motorsport for £66 all in. you can get them on 01322 286 850, they also do kits which includes discs, pads, brackets, braided hoses ( a must for peddle feel ) and brake fluid for around £300
hope this is of some help
Rob
Rob
