wiring up cos twin headlamps
on my escos one it went like this==brown and a red wire should be about the same length will be battery connection (red+
)you should be able to plug in the standard connections from each light,there is a relay fitted in one of the lamps(passenger side)
and blue(i think)quite long wire with a spade connector which connects to the drivers side lamp and there is a brown wire which is a earth what connects around the coil fixings-i hope this helps
They plug into the plug that you pull out the old headlight, the wires are the same colours as the ford ones
Rich
Rich
Not sure about Morette copies
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
