S2 rst - Temperature???
Old Sep 27, 2005 | 07:03 PM
Big-J's Avatar
Big-J
Steer fi the rear!
Default S2 rst - Temperature???
arite guys, what temp does ur s2 rst sit at during normal driving?
thanx, john
Old Sep 27, 2005 | 07:05 PM
Rick's Avatar
Rick
The N of norm - not very scientific i know.
Rick's Avatar
Rick
Shit, meant the M!
Old Sep 27, 2005 | 07:06 PM
Oranoco's Avatar
Oranoco
About half way.
Old Sep 27, 2005 | 07:21 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
same here half way or just below...around 90degrees
Old Sep 27, 2005 | 07:51 PM
rsturbotim's Avatar
rsturbotim
about the M mate
Old Sep 27, 2005 | 08:03 PM
Big-J's Avatar
Big-J
Steer fi the rear!
cool, seems to be the norm. just wasnt sure if mine was running at the right temp. cheeRS fellas
Old Sep 27, 2005 | 08:55 PM
adamS2RST's Avatar
adamS2RST
Yea, driving along, 1/4 (m) sometimes lower, depends on the temps really....
Then when parking up after a drive gets no higher than in between R & O (nearly 3/4) and the fan is in and it brings it back down to 1/4 mark again.
Old Sep 27, 2005 | 10:08 PM
CasperR's Avatar
CasperR
With the pro alloy intercooler 1/4 when driving, but if I stop at a red light and its a hot day it will shoot up to right under the red and then it takes 10 minuts of driving to cool it down again. Fans can't get it cold enough to cut the fans off so they are always running. I'm using a 4x4 cossie temp switch and a 82 degree thermostat.
Old Sep 27, 2005 | 10:56 PM
GrimmeRS2K's Avatar
GrimmeRS2K
M here aswell with a GRS
Old Sep 28, 2005 | 04:01 PM
addiction's Avatar
addiction
about half way or just below
Old Sep 28, 2005 | 04:23 PM
Combi_Chris's Avatar
Combi_Chris
half way is a little too hot , thats when the fans come on, but usually almost half way when driving
Old Sep 28, 2005 | 04:35 PM
SamERST's Avatar
SamERST
Mine using a standard ic sits at a 1/4 if driving normaly it raises to about 3/4 when stuck in traffic though. But as with all my cars i run the fan on a switch so as soon as i come to a stop albeit at a set of traffic lights even i just wack the fan on
Old Sep 28, 2005 | 10:31 PM
DaveN's Avatar
DaveN
1/4 driving normaly and about half way when sitting in traffic. - Have seen it go up to over half way after a really hard run though.
Old Sep 29, 2005 | 09:19 AM
JesseT's Avatar
JesseT
I've set mine to 86-88 degree centigrade.
A.t.p
Oct 23, 2015 07:54 PM
A.t.p
Sep 29, 2015 05:04 PM
`spotty
Sep 25, 2015 11:41 PM
Billy_RS
Sep 13, 2015 04:17 PM
