Best suspension setup on RST???
Old Sep 27, 2005 | 06:26 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Default Best suspension setup on RST???
i'm now leaning towards coilovers so which are the best without spending silly money??
james raby recommended Bilstein, how about GAZ or AVO? anyone else have any of these?
or do sime of you think springs & shocks still do the business? eibachs on Koni's etc??
all opinions help, cheers
Old Sep 27, 2005 | 06:45 PM
Oranoco's Avatar
Oranoco
I have no complaints at all with my Spax kit and firmly believe that coilovers are OTT on a car that is primarily used on the road.
Can't go wrong with Koni adjustable and good springs like Eibach
Old Sep 27, 2005 | 07:08 PM
NUTS RuS's Avatar
NUTS RuS
Depends on what you term silly money, but you get what you pay for unfortunatly, and that goes for reputation and life span too.
Jay at xfactor is doing a good deal on AVO's - but check what they are as they do several different types. Also find out if any mods are needed.
https://passionford.com/forum/viewtopic.php?t=146300
James has his head screwed on - but I am biased on Bilstein so will say no more.
Old Sep 27, 2005 | 07:15 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
thanks for link mate....how much were your bilsteins if you dont mind me askin?
Old Sep 27, 2005 | 07:23 PM
NUTS RuS's Avatar
NUTS RuS
Fronts Ł340 each (Or can be less if you dont need the pukka spherical top mounts) Rears Ł275 each
https://passionford.com/forum/viewtopic.php?t=107112
Or click the sig pic for details
Old Sep 27, 2005 | 07:45 PM
gus's Avatar
gus
i have the same as james and tony
only got the front fitted so far thou as have now taken car off the road for a while
again
Old Sep 27, 2005 | 09:53 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
jeez,my car came with spax sportkit,but ive juss fitted 40mm drop g-max springs,there coming off coz its too low,
fitting 25mm springs instead,and 30mm on the back.
Old Sep 28, 2005 | 06:48 PM
mark-rst's Avatar
mark-rst
I run Gaz coilovers
Ride and handling is spot on
You can get a good deal on them in Burtons with some cash to wave under their nose
Old Sep 28, 2005 | 07:00 PM
gus's Avatar
gus
do you not need a collar on the rear with the gaz ones?
or are they a direct fit?
Old Sep 28, 2005 | 07:10 PM
mark-rst's Avatar
mark-rst
There is a collar but it's already on them so they fitted straight on
Old Sep 28, 2005 | 08:29 PM
akito-man's Avatar
akito-man
did you wear a shirt and tie when you bought them with a collar
A.t.p
Oct 23, 2015 07:54 PM
Fezman1
Oct 2, 2015 01:22 PM
A.t.p
Sep 29, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
