Cossie Altenator's!? r they all the same!?
Sep 27, 2005 | 11:37 AM
R all the altenators from cossies the same!?
i.e.
3dr
2wd taxi
4wd taxi
esc
Sep 27, 2005 | 11:39 AM
no mate
2wd and 3dr i think are the same as they use twin fan belts
4wd are different totally, mount different place and have a multi groove pully
Sep 27, 2005 | 11:45 AM
Mine is a 4x4 saffy one i think with a twin belt will lewis 2wd one fit and work?
Sep 27, 2005 | 11:47 AM
3dr is a v belt alternator with a 70 amp output
2wd sapphire is a v belt alternator with a 90 amp output
4wd is a multi v belt alternator with 90 amp output
Escort is the same as 4wd sapphire
Sep 27, 2005 | 11:48 AM
nige shall i just bring it up for u to look @!?
Sep 27, 2005 | 11:50 AM
stretch can u swap the bits over that make the 4wd multi belt!? i.e. just whack the cogs over!?
Sep 27, 2005 | 11:51 AM
Yes i believe you can as it only a pulley assembly.BUT double check with a electrical place.
Sep 27, 2005 | 11:56 AM
cheers steve!
Sep 27, 2005 | 12:03 PM
early 4wd sapphs were also twin v velt
Sep 27, 2005 | 12:06 PM
Tony can i just swap the pulleys over!?
Sep 27, 2005 | 12:08 PM
Shouldn't the question really be.....if the pulleys can be swapped over can YOU do it???
Sep 27, 2005 | 12:11 PM
Quote:
It should indeed but b19 loves to write essays
Sep 27, 2005 | 12:15 PM
I stand corrected.
Sep 27, 2005 | 12:17 PM
I stand corrected.
I'm sure you are not standing at all you are sat down surfing
Sep 27, 2005 | 12:19 PM
Sep 27, 2005 | 12:22 PM
Actually i was stood when i typed that
How the hell do you reach a keyboard stood up shorty??
Sep 27, 2005 | 12:31 PM
Steve(C10SSE) (as there r 3 steve's on this post!)
so the pulley can be swapped then!?
Nige I will drop the alt up for ya if u like!?
Sep 27, 2005 | 12:34 PM
Quote:
While you are up this way, call in for a beer - haven't seen you in ferkin ages...
Sep 27, 2005 | 12:40 PM
Sep 27, 2005 | 01:30 PM
sounds great lewis cheers
Sep 27, 2005 | 01:37 PM
no probs! u desperate for it!? or just whenever Im around!?
Sep 27, 2005 | 01:38 PM
Sep 27, 2005 | 01:57 PM
Yea m8!
Aint been on here much!
get your ass on MSN thoguh as Im logged in all the time when IM @ work!
Sep 27, 2005 | 01:59 PM
Sep 27, 2005 | 03:51 PM
nope!
My MSN plays up now & again! it also has a twat filter on it so thats probably y your messages dont get through!
i got a new gaff now move in on sat!
Sep 27, 2005 | 03:53 PM
i have a spare one nige
just take the pulley off one bolt
new alternators come with no pulley anyways
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
