radiator fan
Old Sep 27, 2005 | 08:10 AM
withamxr's Avatar
withamxr
Default radiator fan
my rad fan does not cut in causing the car to over heat. i hve checked the fuses and they are ok is there anything else i can check before replacing the fan. if i have to replace the fan what would be the best replacement.i am limited to standard size due to my ic covering the rest of the rad. any help/suggestion appreciated (series 2 )
Old Sep 27, 2005 | 10:35 AM
adamS2RST's Avatar
adamS2RST
Hi mate, i'd be checking the fan switch is ok it'self. Is it a standard S2 fan? check the plug connection on the fan itself... and also check the blue connector that goes to the thermostat housing, you can bridge this connection and the fan will kick in automatically with the ignition on. Also check the temp sender (little rubber boot that pushes onto the head, and is also conected in with the blue plug mentioned above) make sure this is ok, but this just gives you your actual temp reading which i assume is ok?
HTH
Old Oct 7, 2005 | 05:35 PM
ivorbiggun's Avatar
ivorbiggun
Almost certainly the plug/switch on the side of the thermostat which
get very coroded and also very HOT. New switch is about £15 from
Ford and plug is common to most fords and your local breaker will
probably give it to you for nothing. John
Old Oct 7, 2005 | 09:26 PM
bbsheppo's Avatar
bbsheppo
I had the same problem last weekend, got a new one from ford for £8 and takes 5 minutes to fit and solved the problem.
Old Oct 7, 2005 | 10:50 PM
withamxr's Avatar
withamxr
sorted now was the thermostat switch .£6. all sorted. untill wednesday when i was on my way back from sothend pf meet and it ran out of petrol on the 127 with the gauge reading1/3 of a tank
Old Oct 7, 2005 | 11:08 PM
Combi_Chris's Avatar
Combi_Chris
i had this problem , rather than fix it , i use a switch now, lol
Old Oct 7, 2005 | 11:17 PM
withamxr's Avatar
withamxr
got an overide but tbh i think it was bodged and maybe the cause
Old Oct 8, 2005 | 09:17 AM
adamS2RST's Avatar
adamS2RST
and
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
