RS500 Cylinder head on 4x4 block
Old Sep 26, 2005 | 10:01 PM
Escort2.0's Avatar
Escort2.0
Default RS500 Cylinder head on 4x4 block
hi guys!!
last week a friend told me he had a rs500 cylinder head on his 4x4 block. he said a rs500 ch is very special. till this moment i thought the rs500/2wd/4x4 heads are the same (4x4 stronger). same valve guides, the same valves diameter, etc.
so what is right? the same head as a 4x4 head or really special????
thx
Old Sep 26, 2005 | 10:15 PM
daz1968's Avatar
daz1968
I think the RS500 head is same casting as a later 2wd 3 bolt head but may have had a little porting but a previous post a little time ago opened up a can of worms on this subject and I don't think it ever reached a conclusion.
Old Sep 28, 2005 | 08:28 AM
Escort2.0's Avatar
Escort2.0
ok, thx
Old Sep 28, 2005 | 09:33 PM
martinrs500labatts's Avatar
martinrs500labatts
the 500 head has bigger port sizes from the factory.
so can be flowed even bigger.
you can tell the 500 head as it has dowles on the inlet to line the 500 plenue up.
Old Sep 29, 2005 | 03:03 PM
Escort2.0's Avatar
Escort2.0
the port sizes are bigger, but the diameter of the valves are the same as standart. right?
how can i see if it is a real head of an rs500? is there a spacial number on it?
hopper350
Sep 4, 2015 12:53 AM
cossirob
Sep 3, 2015 09:17 PM
Marcus L
Aug 29, 2015 02:18 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
