springs,
Old Sep 25, 2005 | 07:07 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
Default springs,
juss bought some g-max springs,40mm drop,put em on my spax sport shocks,and the car is well too low
wondering if all springs!(s2 turbs) are the same size,and its the coil-up "compression" that gives the drop,or are the springs actually shorter the lower (or bigger in mm) you go?
Old Sep 25, 2005 | 08:59 PM
akito-man's Avatar
akito-man
boing!
Old Sep 25, 2005 | 09:01 PM
akito-man's Avatar
akito-man
dyou know jano?
Old Sep 26, 2005 | 07:20 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Some springs are just shortened which gives the lowered look. But they do not have any extra stiffness they should have due to the less height. This normally ends up with the springs coils touching each other.
Some are made the same height but when weight is added (the car) they sit at a lower hieght than std springs. These type springs would be the better type to use.
IMO anything over 25mm drop is too much unless your car and suspension is setup right for it which 90% of cars are NOT!
Regards
Jano
Old Sep 26, 2005 | 10:02 AM
akito-man's Avatar
akito-man
cheers.yaint got any second hand(good con)ones per chance? (20-25mm)front only.
Old Sep 26, 2005 | 07:52 PM
akito-man's Avatar
akito-man
sorted ,ma mayn man,jamie,(JamboRST),has fixed me with a pair,juss what i was after,
hes got another set if anyones struggling,
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
CrOwSoN15
Sep 24, 2015 01:36 PM
L1AM_RS
Sep 23, 2015 03:27 PM
