T28 on a RST
Problem is that he didn't fit it himself.
If you have a spare manifold it "should" only be a matter of turning the housings around in order to get it to fit the manifold?
I have a T28 on my car and have had this for nearly 3 years now
Its a fairly straight forward conversion, you will need a different down pipe which some one will easily modify for you.
I would deffo recommend you fit this turbo to your car
