is 21psi safe thru a 2wd intercooler???
my car is usual stg.3, greens,-31 etc and the boost is set to 21psi,i have a 4x4 itercooler but havnt got round to fitting it,is it safe to be running the 2wd intercooler??
it's not really a case of if it's safe to run x bar boost through a certain intercooler as if the intercooler is not efficient enough at bringing your ACT down, the ignition should be retarded to take account of it. that will mean making less power and being less driveable, rather than making it dangerous to run (up to a point where the ACT is so high that the timing is not retarded enough to prevent detonation)
Russ Payne
Sep 25, 2015 08:29 PM
