l8 ecu and light blues on 2wd cos.does it need 4x4 tps?
Old Sep 17, 2005 | 08:24 PM
fordsportjay's Avatar
fordsportjay
Default l8 ecu and light blues on 2wd cos.does it need 4x4 tps?
a friend has just put a l8 ecu,light blue injectors on his 2wd sapphire.im sure i have read somewhere that you have to use the 4x4 throttle pos sensor and change 2 of the wires round.
the car is ticking over at 2000 rpm now apparently.
if im right,can anyone shed any more light on it please-ie which wires to swap etc.so i can let him know as he is panicking a bit and its his only car
thanks in advance
jay
Old Sep 17, 2005 | 08:27 PM
GARETH T's Avatar
GARETH T
yes needs 4x4 tsp and the two outer wires swapped
dont listen to anyone who says otherwise
Old Sep 17, 2005 | 08:28 PM
simonc's Avatar
simonc
yes 4x4 tps needed, pf09 i think it is, swap the 2 outside wires over at the tps plug .
Simon.
Old Sep 17, 2005 | 08:33 PM
fordsportjay
thanks you guys and there just happens to be one finishing on ebay in 20 mins so ive put him onto it.
big_Rad
Sep 15, 2017 09:36 AM
Bailes1992
Aug 16, 2015 07:14 PM
CrOwSoN15
Aug 14, 2015 06:52 PM
3i Jim
Was It You?
Aug 1, 2015 06:33 PM
Old ford
Jul 31, 2015 06:50 AM
