Central heating help
Old Sep 17, 2005 | 12:35 PM
pjv7771's Avatar
pjv7771
is the rad in the bedroom under the window ?
Old Sep 17, 2005 | 12:41 PM
pjv7771's Avatar
pjv7771
if your pressures that low it probably wouldnt be worth gettin a bigger rad, is your boiler big enough to cope with the size of the house ?
Old Sep 17, 2005 | 12:51 PM
DOO's Avatar
DOO
make sure the pressure on the combi is on 1bar and bleed all the rads
Old Sep 17, 2005 | 01:19 PM
pjv7771's Avatar
pjv7771
try bleeding the rads first mate after that u have to know wot the btu rating of the boiler is, although in a two bed place i cant see that being a problem
Old Sep 17, 2005 | 02:48 PM
Al Bags's Avatar
Al Bags
It MAY be that they need bleeding .. (No-ones really helpin here!) but it sounds like a circulation issue.
Test this by running the system (when calling for heat) Feel the radiators at the inlet pipe and up towards the top .. If a uniform temperature, then it's likely you don't have air in them .. but if unsure, bleed anyways. (top system pressure up to 2 bar first and again afterwards)
Radiators work most efficiently when there is a certain temperature drop across them .. approx 18-20 deg C. No drop means water is rushing through, and dropping your efficiency. A lot of drop means not enough flow. This is what you probably have . Usually this happens when a system is installed and all the lockshield (outlet) valves are left fully open. What then happens is .. The radiators nearest the boiler pump have water rushing through them (easiest path, remember?) and the furthest ones hardly get any flow. The favourite is the bathroom one.
You can "balance" the system like this ...
Open all the rads to full. Start at the rad nearest the pump (boiler in your case) turn the lockshield valve down to a trial amount of say 1 turn open .. then progress in the same way working away from the boiler til you get to the last (usually the coolest running rads) Leave a while and then check the temp drop across them .. 20C is hard to describe .. like difference between hard-to-hold and just hot (temp testers are good for this job) Dont go down much more that 1/4 turn open on the lock shields. In turn, see what you get. This will balance the system so all rads get the approx same flow and heat up at the same rate.
Only other things I can think of is .. especially if 8 or 10 mm Microbore ... there is a manifold with air in it.
Keep your system pressure hot around 1.5 to 2 bar max. Blow off is set to 3bar in most boilers (thats 42 psi)
Hope that helps .. !
Old Sep 17, 2005 | 02:51 PM
Al Bags's Avatar
Al Bags
Oh! ... and dont miss the bleed in the top of the boiler exchanger .. is letting out any air. It's got in somewhere! Just regularly check the pressure and bleed all the rads to see if it settles. If not, air is getting in somewhere!
Old Sep 17, 2005 | 03:16 PM
Al Bags's Avatar
Al Bags
Hey mate ...
Follow those instructions .. Easy, and will save you on heating bills!
1. Top up the pressure from a flexible "fill loop" This is maybe already fitted between mains water and system .. or dangling ... or not one fitted at all!
Usually looks like a braided stainless steel hose. It has a 1/4 turn slotted valve at each end, usually. open slowly after connecting to the mains, and watch the system pressure rise to 2bar. Then follow what I said about bleeding, balancing, etc!
2. The lockshields will usually be on the outlet ends of rads, except some Thermo valves can be fitted as an inlet OR outlet controller. Thats usually the dear liquid filled head type with chrome caps. So you cant do much wrong.
Only time you should be careful is with a system that has no bypasss valve (NOT a combi) You should make sure that circulation CANNOT be completely stopped.
This is why some bathroom rads that you see have a lockshield at both ends
Back later mate
Old Sep 17, 2005 | 03:19 PM
Al Bags's Avatar
Al Bags
This is a filling loop mate .... This one has plastic taps instead of screwdriver slots!
Old Sep 17, 2005 | 04:19 PM
Andy-R's Avatar
Andy-R
Sounds like you have turned the water off to the boiler hence no preassure and the overheating kettle effect.
Reverse what you have done and the system should preasure'ise again.
HTH
Old Sep 17, 2005 | 11:23 PM
Al Bags's Avatar
Al Bags
Hi mate .. been out welding all afternoon.
Right .. yes, I can see the fill loop in that pic : ) Obviously you sussed how to top up the pressure then.
Over the course of a few days use .. keep bleeding/topping up pressure until it (hopefully) stops dropping.
You will find that as you get most of the air out, the pressure comes up quickly ... only needing a few squirts.
Leave the rads furthest away from (most likely slowest ones to heat up) open more on the lockshields than the near ones.
When the system is balanced, another bonus is that you can knock the pump speed down to possibly minimum .. depending on system volume and circuit length. This will save on lecky, too .. and is quieter in operation!
Remember .. the thing you want to get is that 18-20C drop across the rads if poss.
SYL
nico12
Dec 31, 2015 04:42 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
cossie09
Sep 10, 2015 06:56 PM
