Is it ok to run with the amal valve disconnected?
Will it cause any problems running a stage 3 cossie lump with the amal valve disconnected? Will it cause overfuelling or anything?
Also it only goes to just under 10 psi, whats sort of BHP will that be?
because the engine is going into my mk1 escort, which is still running a english axle. If I run full power the axle is not going to last that long and I cant afford and find a decent atlas axle yet.
So was toying with the idea or running with the valve disconnected for a while.
gchristophi
Aug 31, 2015 10:36 PM
