Mondeo 2.5L V6 GHIA X - ESP - What does this do ?
Hi there
Took my recently acquired Mondeo out for a decent spin last night to put it though its paces a bit - the orange warning light for the Electronic Stability Program came on on the dashboard as I turned quite sharply and stayed on until I turned off engine and turned back on again.
Can anyone advise me what this function actually does - and if this is normal ?
Thanks
Si
Thanks
Si
Dont know the full name of it but its like a stability control.Controls traction under accelration and cornering.Floor it in a straight line and it will genrally stop you from spinning.Do it with half lock or full lock on n the crazy thing will stop you from going anywhere.If you want a quick get away its just in reach of ya finger to turn it off while ya hand on gear know.In my 220 it is anyway.
Good thing to have to stop you getting it out of shape.But bloody dangerous to have on if your pulling out in front of a truck and need to get a quick get off.it just bogs you and deliberatly stops you from accelerating.Only way i can put it is it stals you.
If you turn it off light appears on dash(car with skid marks behind it).sometimes ive noticed with some electronic gadgets in the mondeo you do have to switch car off and restart to reset itself dont know why.
ian
ian
Traction control on mine doesnt seem to work when you pull off and turn at same time, spins up like fook till u straighten up then it cuts in. The car bounces around like fook when you turn it off and give it some tho.
Then do the same with the light on and see the difference.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
The Enigma
Sep 29, 2015 10:31 AM
