dump valve removal question
Old Sep 12, 2005 | 07:14 PM
jaiscossie's Avatar
jaiscossie
Default dump valve removal question
i want to take the forge dump valve off my saff cossie, do i need to refit the standard ford plastic one on the other side as it has been removed and bunged up. also how do i get the loudest wastegate noise?
Old Sep 13, 2005 | 10:31 AM
RSCosworth's Avatar
RSCosworth
u get a very loud noise by open filter and no dump.
Old Sep 13, 2005 | 04:27 PM
Dean Saff's Avatar
Dean Saff
make sure you blank off all the boost pipes and the vacume pipe that goes to the top of the dump valve.
If you want louder chatter then you will need a cone filter, then its pretty much a case of the more boost you run the louder the chatter, Im not suggesting you just wind your boost up mind.
Old Sep 14, 2005 | 02:14 PM
Stealth Bomber's Avatar
Stealth Bomber
Chatter has gotta be one of the most important things in life
Old Sep 14, 2005 | 05:11 PM
KSA-Cossie's Avatar
KSA-Cossie
Old Sep 14, 2005 | 05:53 PM
jaiscossie's Avatar
jaiscossie
i know that i have to block off where dump valve is and the vacume pipe but do i need to put the standard black plastic ford on back on , on the left hand side?? i have a large k&n and run 21psi
Old Sep 14, 2005 | 06:02 PM
Dean Saff's Avatar
Dean Saff
No blank it off
Old Sep 15, 2005 | 04:47 PM
jaiscossie's Avatar
jaiscossie
cheers dean, so why did fords put the plastic one on then? is it not needed? also my car wastegates but not that loud? how can i make it louder?
Old Sep 16, 2005 | 12:48 AM
cossiemen's Avatar
cossiemen
Whassup
more boost = louder chatter
Old Sep 16, 2005 | 01:03 PM
foreigneRS's Avatar
foreigneRS
Testing the future
the amount of flutter noise that you get depends on how quickly you close the throttle and at what boost and what engine speed. if you drive like a twat and just snap the throttle shut at full boost at mid range rpm, you should get the most noise, as more air will be in the inlet going back out past the compressor
Old Sep 16, 2005 | 05:43 PM
Dean Saff's Avatar
Dean Saff
I think they were fitted from factory for the opposite reason to why you want to take it off, keeps them quite.
cossie09
Oct 11, 2015 06:29 PM
YODI
Aug 30, 2015 01:12 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
Churtz
15
Aug 13, 2015 06:40 PM
rsstav
Aug 11, 2015 04:22 AM
