abs light come on pls help
Old Sep 11, 2005 | 07:38 PM
jaiscossie's Avatar
jaiscossie
Default abs light come on pls help
the abs light came on today on my 2wd saff now it wont go out?? what is causing this?
Old Sep 11, 2005 | 10:51 PM
Hectori's Avatar
Hectori
try to clean and aply contact creace to the ABS connector.
Old Sep 12, 2005 | 07:49 AM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Do a search for ABS light on here, you'll find loads of threads on the subject
Old Sep 12, 2005 | 10:26 AM
Stealth Bomber's Avatar
Stealth Bomber
Same problem on mine, and the ABS deffo ain't working as I found out in the rain the other day...
Old Sep 13, 2005 | 08:44 PM
vyper developments's Avatar
vyper developments
Hi,
In my experience of this ABS system if you have an amber light on the dash and you are able to put it out it by switching the ignition off and then back on again then it is usually a wheel sensor related problem.
If however the light stays on permanently with ignition on, it is usually something within the system itself. Quite a common problem (I would check first) is a lack of normal battery voltage (NBV) at Pin 2 of the ABS ECM, this can sometimes be caused by a bad connection when aftermarket alarm/immobilliser's have been fitted around the normal supply from the ignition switch and sometimes the wiring gets disturbed.
CheeRS, Mike.
Old Sep 14, 2005 | 04:40 AM
dox's Avatar
dox
yep, well said i had the same problem
Old Sep 14, 2005 | 05:50 PM
jaiscossie's Avatar
jaiscossie
cheers guys , i went to try and sort it today and to my amazment the light has gone back out now well for now ......
Old Sep 16, 2005 | 05:38 PM
dojj's Avatar
dojj
Resident Wrestling Legend
also try changing the brake fluid
muzzman1
Sep 30, 2015 08:59 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
