What are these adjustable TCA's off
Old Sep 9, 2005 | 03:34 PM
S1 JOHN's Avatar
S1 JOHN
Default What are these adjustable TCA's off
Got these arms in a box of spares when i bought a series 1 and a mk3 cab so i presumed they were for one of these but they arent the same one is straight and one is cranked
The straight one:
The cranked one:
The pair see the difference:
The part Nos , not they will probably mean anything to anyone but the company who supplied them :
anybody got any ideas ??
Tried looking round ebay for some the same but no joy
Old Sep 9, 2005 | 03:51 PM
ian sibbert's Avatar
ian sibbert
TAS....trans auto sport from preston.....http://www.tas.uk.com/
Think they went BANG a little while ago mate...
regards
Ian
Old Sep 9, 2005 | 03:58 PM
S1 JOHN's Avatar
S1 JOHN
thanks very much mate according to there web site the part No's i have are both for my car just weird how one is cranked and one isnt
Old Sep 9, 2005 | 04:15 PM
S1 JOHN's Avatar
S1 JOHN
tried ringing them the line is dead
Old Sep 9, 2005 | 04:20 PM
Dave Henshall's Avatar
Dave Henshall
if you weigh up the pics, the thay will fit the same albeit handed as they should be , one has the whole arm cranked and the other has the hole part set at an angle, these would fit as a pair i reckon... like so,, no autographs for the artwork please
Old Sep 9, 2005 | 04:33 PM
S1 JOHN's Avatar
S1 JOHN
thats what i thought i think its gonna have to be jack it up and try it but according to that site there right for my car .
What goes either side of the rose joint though ?
Ive got a full polybush kit to fit but i dont wanna start fitting it till i get these on
ps loving that drawing dave looks like it should be pinned up on the fridge
Old Sep 9, 2005 | 04:37 PM
Dave Henshall
there shoule be some spacers that go either side to pack the rosejoint centrally in the opening, i suppose you could use several washers either side or a small lenght of metal pipe cut off at the right length to slide over the bolt either side.
Old Sep 9, 2005 | 04:39 PM
Dave Henshall
just seen these spacers in broms kit.. top right hand side...
Old Sep 9, 2005 | 04:41 PM
S1 JOHN's Avatar
S1 JOHN
So what happens to the inner tca bushes not used ?
Any idea where you could buy the spacers ?
The place the arms are from has gone tits up
Old Sep 9, 2005 | 04:43 PM
Dave Henshall
nope,
as i say, you could probably get away with getting a small length of pipe the right OD and cut 4 pieces off with a hacksaw
Old Sep 9, 2005 | 04:57 PM
S1 JOHN's Avatar
S1 JOHN
looks like thats what ill be doing either that or it will be another lot for ebay
Old Sep 9, 2005 | 05:00 PM
ian sibbert
I can do you some spacers mate....the are just machined bar with a hole bored through the middle you'll have to have a trip to lancaster to collect....the turbo's are 12mm inner tca's? would just need the dimensions of the housing on the X member and the width of the ball in the rose joint.....
The rose joint replaces the inner tca joint......
Regards
Ian
Old Sep 9, 2005 | 05:10 PM
S1 JOHN's Avatar
S1 JOHN
you got a rough idea of price and a contact no i can reach you on pm me if you want
Old Sep 9, 2005 | 06:40 PM
NUTS RuS's Avatar
NUTS RuS
The rose joint spacers (if done proper) should go part way into the rose joint, so a bit of machining may be necessary.
We have them in stock in stainless steel made specifically for our sized rose joints.
Ours are offset spacers done like that to keep the original factory castor settings. Some makes of adjustable TCA's will push forward the castor by a small amount if the r/j spacers are central.
The cranked and straight arms make no difference, if you draw a line from the centre of the ball joint top it should be straight right through to the centre of the rose joint.
Old Sep 9, 2005 | 11:28 PM
CozzyBrom's Avatar
CozzyBrom
thats easy
stright one is off a s1
cranked one off a s2
normally
if one a s1 make no diffance as you can ajust the castor angle
id its a s2 then by one of my tie bar kits
yatta
May 21, 2016 10:31 PM
mk1turboestate
Dec 2, 2015 08:31 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Mark V8
Sep 13, 2015 09:34 AM
