ESCORT RS COSWORTH
cash waiting for a clean well looked after example
im not gonna be anal about mileage, owners or paint as long at the car runs well and is at the right price
steanomi16@hotmail.com or 07779271767
cheers
cheers
Hello mate, looking at the 14k mark for mine.
You won't be dissapointed on viewing with this one, got all the extras like protection film on the paintwork, stage 3, new suspension and set up all done last august.
Only reason I am selling is due to a mate selling his RS500, so I wanna pick that up.
Thanks mate and good luck!
I am selling my cossie cos am buying a house am looking for £13500 ono
just spent £4000 and much more on the engine reubuild by dave brookes in crewe the engine is not run in yet it has only done 600 miles the engine has been done to handle 450 bhp the car is in very good condition got all the old mots & full service history
johnclarke@bulldoghome.com
ford escort cosworth K reg 1993 big turbo motorsport model
Only done 4600 miles from new
john
Heres a list of whats been done
remove exhaust valves guides port & gas flow to race specification
reface valves,cut seats fit 8 new exhaust valve guides
grind in valves hand finish port throats reface cylinder head
bore cylinder block to wrc pistons using deck plate
reface flywheel
jig bore small end bushes
balance complete assembly
machine pistons to 7:9 compression ratio
brand new block
Brand new low comp wrc pistons with valve cut outs
cambelt kit power grip
uprated fuel pump
3 bar map sensor
T 35 Turbo
grey injectors
koni all round
uprated brakes tarox drilled and groved all round
poly bush kit
collins performance chip
full mongoose stainless exhaust and downpipe with middle box cut out by collins performance
Uprated Fuel Pressure Regulator
baileys dump valve
full samcos set
air brushed rocker cover and camcover and heat shield in green marble
Morette Twin Headlight Conversion
18"alloys
dvd player with sub & amps
if u need photos of my car email me back
cheers
john
john
reface flywheel
brand new block
uprated fuel pump
3 bar map sensor
T 35 Turbo
grey injectors
koni all round
poly bush kit
baileys dump valve
full samcos set
18"alloys
cheers
john
MAD RST yours is sweet but you wont come down on price !
