4x4 saph front prop
Old Sep 9, 2005 | 08:22 AM
slowpoke's Avatar
slowpoke
Default 4x4 saph front prop
someone, i think it was dave henshall said you could get a new UJ from woodford ?????
how much are they ? and how easy to replace it ?
even if that isnt my dodgy noise i may just replace it anyway after the horror stories ive heard
cheers everyone............matt
Old Sep 9, 2005 | 04:42 PM
slowpoke's Avatar
slowpoke
up for dave to see
Old Sep 9, 2005 | 04:57 PM
Dave Henshall's Avatar
Dave Henshall
it wasnt me, but yes simon at woodford does stock them about 25 quid i think, and they come with a grease nipple pre installed IIRC so you can keep it lubed up in the future
Old Sep 9, 2005 | 05:04 PM
slowpoke's Avatar
slowpoke
cheers dave are they easy to change do you know ?
Old Sep 9, 2005 | 05:07 PM
Dave Henshall
not too hard, cant remember though if the needle rollers are held in with circlips though of pressed in, you need to unbolt the front prop, but i havent done one myself to be sure....
Old Sep 9, 2005 | 05:29 PM
Damo V's Avatar
Damo V
circlips
Old Sep 9, 2005 | 05:48 PM
slowpoke's Avatar
slowpoke
is it possible to remove the whole front prop and then fiddle with it ?
Old Sep 9, 2005 | 05:50 PM
Dave Henshall
indeed, mark up though in what position it was when u take it of either centre punch the flanges at each end on both the shaft anf the flanges to the/from the boxes
Mr RS500's Avatar
Mr RS500
Its the best way ,,remove it from the car and its a piece of piss mate
Old Sep 9, 2005 | 05:52 PM
Damo V's Avatar
Damo V
you will need something to drop the transfer box fluid into, it requires half a litre if you put fresh in
Old Sep 9, 2005 | 05:59 PM
slowpoke's Avatar
slowpoke
can all this be done on those drive on car ramps ie the shitty small ones ??
Old Sep 9, 2005 | 06:04 PM
Damo V's Avatar
Damo V
Yeah, just bring the back up 6 inches or so also maybe
Old Sep 9, 2005 | 06:07 PM
ryan_belfast's Avatar
ryan_belfast
Make sure you keep this little fucker greased as you remember my horror story in my escort cosworth? 150mph booooom came off, blew everything, diff, gearbox clutch etc....KEEP IT GREASED!!!
Old Sep 9, 2005 | 06:19 PM
Mark V8's Avatar
Mark V8
I had to drop the exhaust and anti roll bar to get the front prop out.
U.J I got from local motor factors.
Quinten Hazel Part number QH QL16103
Cost me £26.88 incl VAT
Mark
Old Sep 9, 2005 | 06:23 PM
Damo V's Avatar
Damo V
I does come out without taking those off On my car...
Old Sep 9, 2005 | 06:57 PM
slowpoke's Avatar
slowpoke
so if i buy the uj from woodford whats actually in it ie the whole universal joint or is it just the innards of one ?
Old Sep 10, 2005 | 09:38 AM
Damo V's Avatar
Damo V
It will be the + bit which joins the shaft tto the flange
Old Sep 10, 2005 | 09:39 AM
Damo V's Avatar
Damo V
https://passionford.com/forum/viewto...ghlight=grease
Have a look there mate for more info
DixieTheKid
Jul 23, 2023 10:16 AM
FlashRS
Sep 14, 2015 12:36 PM
cossie330
Aug 22, 2015 12:00 PM
C2 MAK
Aug 20, 2015 09:46 PM
