oil cooler
Old Sep 9, 2005 | 07:58 AM
raycov's Avatar
raycov
Default oil cooler
is it any use fitting a oil coolant rad on a 250bhp plus 1.9 zvh conversion so i can keep the oil at a really steady temp because i think it might be getting a bit to hot
Old Sep 9, 2005 | 11:35 AM
Micky's Avatar
Micky
How hot is it getting???Regards Micky
Old Sep 9, 2005 | 06:06 PM
raycov's Avatar
raycov
ive got farenheit gauge. if i just go down the road 10 minutes it goes up to about 170 and when i stop it still keeps rising as it should but i dont when it will stop ive been told not to let it go to 220 max. i went in the m1 the other week ,water and oil temp and pressure read 150 w 160 o and 60 p when i stopped everythink over heated ,maybe if the water is cooler the oil might be.
cheers micky
ray
Old Sep 10, 2005 | 02:52 AM
Micky's Avatar
Micky
Ok,160 degree Fahreinheit is what youre getting for oil temp,yes??That is ok and nothing to worry about.As an example i get 257 degree Fahreinheit/125 degree Celsius when out on track,so does Tim Butcher is his Norris Motorsport S2,so you can see youre way below what us lads get on track.I think raycov youre not trying hard enough,LOL .Regards Micky
Old Sep 12, 2005 | 08:35 AM
raycov's Avatar
raycov
thanks micky
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
