Saff cossie offset
Old Sep 8, 2005 | 05:30 PM
lamb chops's Avatar
lamb chops
Default Saff cossie offset
Whats the offset for wheels on a saff? just looked at my new Mo's and they are 30 where as my RS7 diamonds were 35..
CHeers
John
Old Sep 8, 2005 | 05:48 PM
Jim Green's Avatar
Jim Green
ET40 is stamped on standard 2wd wheels
Old Sep 8, 2005 | 05:58 PM
lamb chops's Avatar
lamb chops
Thanks Jim, I just checked the standard rims I have on mine and have seen that too.. I wonder if 30 is an escort offset..
Old Sep 8, 2005 | 05:59 PM
SPADGE's Avatar
SPADGE
Standard wheels on 2wd saffs are et35 4wd et40
The MO's should be ok on the rear but dependant on what size they are and what size tyres you intend using they will be a bit touch and go on the front!
Old Sep 8, 2005 | 06:03 PM
Jim Green's Avatar
Jim Green
Sorry Spadge, Have to disagree there..... Had my sapphire since it was just over a year old, and still have the original wheels in the garage. Just checked them.....All marked ET40 on one of the spokes, and she's definately 2wd....
Old Sep 8, 2005 | 06:04 PM
SPADGE's Avatar
SPADGE
News to me Jim but i'll stand corrected!
Old Sep 8, 2005 | 06:06 PM
RichardPON's Avatar
RichardPON
I've got ET30s on the front of mine with flared arches, so on standard ones, it'll be close!
Old Sep 8, 2005 | 06:12 PM
Jim Green's Avatar
Jim Green
SPADGE : We all learn something every day Spadge, Even me, but it's definately ET40 on a 2wd Sapphire.
Yet another beer you owe me.....
Old Sep 8, 2005 | 06:47 PM
lamb chops's Avatar
lamb chops
Thanks guys, Richard got any pics of the clearance? Ive got coilovers and was expecting to have the arches rolled anyway.. Better get some 215\35's ordered.
Old Sep 8, 2005 | 06:51 PM
Jim Galbally's Avatar
Jim Galbally
anyojne know the offset of boddo std GLSi on the rear? and what actually affects the rear ofset anyway? what part determins the offset (ie if mine are different, what bit do i need to change? )
ps pon, do you still have your old 2wd Beam?
Old Sep 8, 2005 | 07:57 PM
Jim Green's Avatar
Jim Green
LAMBCHOPS : Go for Falken 225/35/17 from Pro Tyres at Fareham. You can always try one of my wheels to make sure you have the clearence first....
Great tyre in the dry
Old Sep 8, 2005 | 11:06 PM
MAD Ade's Avatar
MAD Ade
Chopper,
you'll deffo need the arches rolled. If you can borrow a wheel from a mate with the same offset it's worth trying. Max tyre size I would go for on the front is 215/40. That's with roughly standard ride hight.
Ade.
Old Sep 9, 2005 | 01:58 PM
lamb chops's Avatar
lamb chops
Thanks for the offer Jim, these buggers are 18" though. Decided im going to hold off till she back on the road again next year anyway.
Ade, going to play it extra safe and go 215/35
Old Sep 9, 2005 | 02:08 PM
RichardPON's Avatar
RichardPON
I'm on a 215/35/18 MO ET 30, and I haven't got any recent pics of here down on the ground....... Only thing I have is
Not very clear - can get some pics next week at some point.
Old Sep 9, 2005 | 02:15 PM
Spiky's Avatar
Spiky
Jim Galbally,
you need a beam??
Old Sep 9, 2005 | 02:27 PM
Jim Galbally
spiky, you got one? i want a beam + diff (well, everything bar brakes) wanna slap some polys in and bolt it up. sourced one for 200quid already polybushed (with diff!) but the guy's too lazy to take it off the car
Old Sep 9, 2005 | 02:30 PM
Spiky's Avatar
Spiky
my mate has a beam and drive shafts, 2 infact
PM 3dr-rally-slag
Old Sep 9, 2005 | 03:03 PM
SPADGE's Avatar
SPADGE
Had 215/35/18's on my old taxi for a while with ET35's all round
Was also running coilovers and had no probs at all! The extra 5mm yours stick out (assuming they are 8j?) may make a difference dependant on how low you want to run it.
Old Sep 9, 2005 | 03:04 PM
SPADGE's Avatar
SPADGE
btw as you can see my arches wern't rolled either
Old Sep 9, 2005 | 04:00 PM
DOO's Avatar
DOO
Normal off set on standerd alloys are 40et both for 2wd /4wd
my 18 MO`s are 8j x 18 35et
Old Sep 9, 2005 | 04:26 PM
Jim Green's Avatar
Jim Green
DOO : You are indeed correct. Both Sapphires (2wd and 4 x 4) are the same off-set. (ET40)
Old Sep 9, 2005 | 04:37 PM
SPADGE's Avatar
SPADGE
Can we just clarify what the normal offset is Would it be 40 by any chance
Anyway the standard offset is of no relevance when you are putting wider wheels than the original 7j ones on! The et40 was obviously chosen to give the correct clearance on both sides of the wheel for the 7j rim and 205 tyre. Try using a 40 with 8j 18's and 215's or wider and i promise you they won't fit without fouling the front suspension and looking stupid
Old Sep 9, 2005 | 07:11 PM
lamb chops's Avatar
lamb chops
Thanks for the pics chaps it does help, I got the wheels from Mike, Dangerous - Reyland and he had them on his track saff. Like a fool I forgot to confirm the offset before buying them as a just presumed..
Doo I have spent a fair amount of time studying that pic of yours already couldn’t quite make out the 35 though
Old Sep 9, 2005 | 08:11 PM
Jim Green's Avatar
Jim Green
But the Off Set can also drasticaly affect the way the car drives....... Tram Lines like hell on anything than a perfect road surface if you get it wrong. Just like mine
Old Sep 9, 2005 | 08:13 PM
SPADGE's Avatar
SPADGE
Jim it will tramline on 18's regardless of offset!
Your Taxi is probably just used to pulling over to the kerb all the time to pick-up fares
Old Sep 9, 2005 | 08:36 PM
lamb chops's Avatar
lamb chops
There has been a change of plan now.... doh im not sure I want to do this!!!
http://bbs.rsownersclub.co.uk/showthread.php?t=78148
Old Sep 9, 2005 | 08:38 PM
Jim Green's Avatar
Jim Green
Pullilng over to the kerb to pick up girls hopefully..........
Old Sep 9, 2005 | 08:39 PM
SPADGE's Avatar
SPADGE
kerb crawler
Old Sep 9, 2005 | 08:41 PM
Jim Green's Avatar
Jim Green
Shhhhhhhhhhh
Old Sep 9, 2005 | 08:47 PM
Jim Green's Avatar
Jim Green
Chopski...... Hope your doing the right thing...
Old Sep 9, 2005 | 08:53 PM
lamb chops's Avatar
lamb chops
Yes me too Jim... I think its one of these things I need to try. Every time I see some pics of a nice 3door I want one.. Don’t want to spend anymore money on the saff if im going to sell it. Hopefully that makes sense..
Old Sep 9, 2005 | 08:55 PM
SPADGE's Avatar
SPADGE
Can't look on the RSBB as still banned lol
So what was the link to???
Old Sep 9, 2005 | 08:58 PM
lamb chops's Avatar
lamb chops
hehe Spadge, its a for sale thread for the old saff mate. Decided im going to the 3door root!!
Old Sep 9, 2005 | 09:03 PM
SPADGE's Avatar
SPADGE
I see! good decision although i do like your saff and remember it from a Herts meet a couple of years ago when Pons bro owned it
Better off with the 3 door though mate as they are much more astheticaly(sp) pleasing with much more prescence
Old Sep 9, 2005 | 09:06 PM
lamb chops's Avatar
lamb chops
Thanks Spadge, never driven a 3door but just love the looks and the pedigree. shame your black ones gone as that would have been ideal.
Old Sep 9, 2005 | 09:11 PM
SPADGE's Avatar
SPADGE
I've owned 12 mate at the last count
Yeah the black one was ok but a mate of mine has a nice white one for sale at the moment which i would suggest you see if you get a buyer on the saff
Old Sep 9, 2005 | 09:24 PM
lamb chops's Avatar
lamb chops
12, I would be happy with just one!!, I want a white one so i will be in touch if I do
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
ajamesc
Sep 27, 2015 02:25 PM
Russ Payne
Sep 25, 2015 08:29 PM
