Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
Brakes
Old Sep 7, 2005 | 09:14 PM
marcos's Avatar
marcos
Default Brakes
Anyone out there reccomend a decent braking system for my mk2 escort running 16inch rims using willwoods at mo but they are crap.
Old Sep 8, 2005 | 07:25 AM
John Doe's Avatar
John Doe
why are they crap... what are they doing and tell us your complete braking system
Old Sep 8, 2005 | 08:50 PM
marcos's Avatar
marcos
the braking system is as wilwood superlite 4 pots 257mm vented grooved discs rear sierra cossie discs and calipers bias pedal box 0.725 front master cylinder 0.625 rear master cylinder twin remote servos in the boot. cant get them to work as they should pedal not there at all.
Old Sep 8, 2005 | 10:31 PM
John Doe's Avatar
John Doe
not surprised with the 2 servos.... bin them, you wont feel a pedal at all with them and wont know what the brakes are doing... also can you put a pic up of your rear brakes, need to see the pipe work...
I have race cars running that set-up and the drivers can lift the rear axle up on hot slicks, so i would say its a minor problem you have with them, also have your front calipers got the bridge bolt to hold the pads in or a pin..
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
